I’d like to suggest an idea regarding ihost casting. Could you create certain input or output shapes that can then be assigned to devices? For example, an output brightness shape that I could use for a dimmer device, an output temperature shape that I could assign to a thermostat device, and so on. Basically, like WinCC or similar SCADA systems, for data acquisition.
Do you mean like the iHost “display as” but simpler?
Alguna vez has usado un scada como wincc, te dejo un enlace para que se me entienda.
mira a partir del minuto 7:00min, vera como se inserta botones, barras, etc… y luego eso se asocia a una variable, sensor, etc…
