Can't connect to my Sonoff L3-5M-P
I am unable to connect to my Sonoff L3-5M-P and i have tried changing my band to
2.4 (B+G+N) but its still not working. A solution would be really helpful.
Please check this post, perhaps you can find something useful:
I am having the same issue which irritates users. This debugging message keeps popping up:
Can’t you update?
Ok. Solved it the following way:
  1. Change my router to only have 802.11b
  2. Reconnected the L3-5M the usually way
  3. The Bluetooth message didappread; the device not connected disappeared.
  4. Waited a few hours and eventually it came up with an upgrade available
  5. Device now connects without any problems.
Tomorrow I will change the router back to 802.11b/g/n and see if it still be connects without any issues.
Hi there, the same is happening to me. Did you manage to solve the issue?
The L3-5M is a dud. Due to the use of an archaic microcontroller, it requires you to lower the parameters of your WiFi network to connect, which will adversely affect other devices you connect to it, or to install an additional router exclusively for the L3-5M. In my opinion, it’s best to throw it in the trash and accept that Sonoff has once again let us down…
