Camera CAM-B1P & NSP panel
Camera CAM-B1P se nezobrazuje na NSP panelu.Proč?
May I ask if you first added the CAM-B1P to the eWeLink app and then couldn’t add it to the NSPanel Pro?
If so, you can do the following:
Find the NSPanel Pro, enter split-screen management — if you want to add CAM-B1P to split-screen 1, edit split-screen 1 — add a widget — select CAM-B1P. Once saved successfully, you can view the camera feed on the NSPanel Pro.
If you prefer to use RTSP, you can add the camera address in the NSPanel Pro settings page. After saving, the camera will also appear in the camera list on the NSPanel Pro.
(Note: Before performing these operations, please make sure both the app and NSPanel Pro are on the latest versions.)
I have recorded a specific operation video for your reference. If your issue remains unresolved, feel free to contact me anytime.
