BUGS HUNTER Part 3
CubeOS has long-term not been recording with SNZB-05P. The last entry in the history was on 28.1.2026. Meanwhile, during testing I immersed the sensor several times and dried it. Since it constantly reports a water leak, it causes problems.
The motion sensor from which I removed the battery and is therefore turned off is constantly reported by CubeOS as functional.
iHost log: 1778337687013.tar.gz
Hello, thank you for your feedback and the logs provided. Was the SNZB-05P sensor added to iHost via local Zigbee direct pairing or via eWeLink Smart Home add‑on synchronization? If convenient, please also provide the device ID of this sensor. Thank you for your cooperation!
The sensors are paired via Zigbee. Sensors are paired via zigbee.
Thanks for your feedback, and we sincerely apologize for the unpleasant experience.We will investigate your issue as soon as possible and will get back to you promptly once we have an update.
To help us troubleshoot the issue, could you please confirm whether you have disabled the operation log recording function? Because when we analyzed the logs, we found that they are reporting the device status normally.
