snzb-06P sensor node-red does not provide information about motion detection
snzb-06P sensor added to IHOST v2.0 in node-red does not provide information about motion detection. There is only information about rssi and illumination.
feedback 211737
Everything worked fine. The problem occurred when I removed the SNZB-06P sensor from Ihost. After adding the sensor to ihost again, there is no more information about motion detection in node-red.
We’ve checked the pic from feedback.
It’s the report of motion unavailable in iHost or unavailable in node-red?
This is a picture and Logs from node-red. Logs from ihost are over 55MB and could not be added.
So it’s both node-red and iHost that cannot report the status of motion?
In ihost the motion sensor status is displayed.
In node-red there is only a report about RSSI and brightness.
The problem affects all sensors. When adding sensors to IHOST CUBE v2.0 it is not possible to check the status in NODE-RED
Sensors added to ihost Cube 1.14 report status normally
I just found that my problem has already been discussed on the forum.
there is a new update. (node-red-contrib-ewelink-cube v1.2.3)
In host cube 2.0.0 the sensor still doesn’t show any movement in node-red.
In my case of the node-red with this fix they released, all the problems they had were solved.
Maybe in your case you have to get updated from iHost as well.
But after a long conversation via Ticket and logs and etc… they were able to replicate the error and correct it. That in my case.
If you haven’t opened a Ticket I recommend opening and sending the ihost nod-red logs and whatever is causing the problem.
Hi, I 've got the same issue. I opened a ticket but still no response. I have installed ewelink cube version 2.1.0 and node red version 4.0.2 and node-red-contrib-ewelink-cube v1.2.4. The sensor SNZB06P is updatre with fw version 1.0.6. I have another ihost with the same app installed but with no issues and with detect mode available on node red.
Hi, Maxxiom.
It’s already answered in ticket.
