I’d like to use a multi sensor like OWON PIR_313-A (movement/temp/humidity/luminosity). Right now I paired a device but is is seen as movement detector only, no temp/humidity/luminosity. How can I improve that ?
Hey,
Thx for the feedback!
We are preparing a new feature, allowing iHost to expose all supported entities from Zigbee devices in UI. As of now, such all-in-one sensors won’t work as expected.
See the manual and observe page 4. Try swapping DIP switch 4 position and hope for the best. Note that changes made with the switch are effective only after you re-pair the sensor. They’re not affective right away. There’s nothing else you can do.
Which manual are you talking about ? I only see iHost User Guides - SONOFF Official and https://sonoff.tech/wp-content/uploads/2023/08/说明书-iHost-V1.0.pdf - no mention for DIP switches ?
Nice, when is it supposed to come ? is there a way to help.test ?
Thx for your kind offer,
We will keep you updated once we have it prepared for the pilot test ![]()
The manual for your OWON PIR_313-A I’m talking about. Don’t you have it? See here.
Ok, strangely enough I removed the batteries and saw no DIP switch… strange. So thanks for the idea but it’s a dead en unfortunatley
Take a better look. It’s very tiny ![]()
Very ![]()
Your make is different then. I’m sorry.
Only the luminance part is really missing. But how do I get the iHost consider it is not only motion detector, but temp and humidity as well ? Is there a file I could update with the file browser ?
You can’t do this. There’s no way to change it by yourself.
Hey,
It is not supported yet.
A workaround would be Node-Red, where you can use event-state to subscribe to its state changes and make a filter to split it up.
Hey great idea ! And I could register a dual temp/humidity sensor to send back to the gui !
You can. Probably.
I deleted and added the device back with 2.0.0 firmware, but for now nothing seems changed :
still detected as motion only
all event gets through the operation log
But only rssi/detection were reachable with node-red
I say “were”, because since I upgraded node-red to the latest version as well, I don’t get the motion events anymore, and I don’t have the ability to filter on motion detection events as well(“Detect” not being present in the list) :
Is there a possibility to rollback/fix node-red add-on please ?
Is there something I can do to improve the multi-device compatibility or is it just a matter of time again ?
