After this update, it’s not possible to select devices other than lights and servo valves, and it’s not possible to select, for example, Minir2 Extreme to control the heat pump. The whole heating system is not working!!!
I’ve paired a zigbee light switch with 6 switches in total, and have been only seen 4 of them show both in the app and also in the nspanel pro. The odd part is that using the ‘apple home’ app in my iphone shows the whole 6 channels, and I indeed, can turn on and off the 2 channels that aren’t being showed in the ewelink/nspanel pro!!
This means that: there’s no problem with the light switch itself, the thing is that both the panel and the app aren’t coded to show 6 switches, even if they are being acessed by the device to expose it to the matter bridge…
Hi, based on your screenshot, I suspect that the “Záložný zdroj vody” device may already be selected as the heat source for another central thermostat, or as the heating switch for a room thermostat. This could be why it is currently disabled and cannot be selected.
I saw in the video that you can select “Záložný zdroj vody” on NSPanel Pro, but you’re unable to select it on the local web page, correct?
Since the local web page does not currently support uploading logs, you can first submit the logs from NSPanel Pro so we can check whether there are any abnormalities.
At the same time, I’ll also try to reproduce and test the issue based on your situation.
Could you please send me the name or ID of the device that cannot be selected? This will help us locate the issue more quickly and assist you in resolving it.
At the same time, please also submit the logs from the NSPanel Pro screen.
