AIR GUARD SAWF-07P & SAWF-08P: When supported at i-HOST and CUBE OS
I’m also interested in whether there will be anything. 64 bit would be enough, I wrote a mini nvr that would run in docker. I complicated it for a 64 bit system.
I agree, a 64-bit system would be sufficient. But what’s most annoying is that Sonoff representatives have stopped talking about the new iHost. No news, no progress, nothing. They’re just silent.
Maybe they can’t say anything about whether there will be a new iHost.
I will have a mini server in the rack. I will set up CubeOS in a virtual machine there and run the NVR.
Hi All!
I connect sawf-08p to my eWelink. All works fine.
I has iHost with CubeOS 2.10.0. And in the docker eWelink Smarthome I do not see sawf-08p. I see only several 4-channels relay, which I sync previously.
Is any suggestions?
Jury
Like you, I have a SAWF-8P on my i-HOST with version 2.10.0 and I also use the eWeLink app.
First, make sure that the SAWF-8P appears in the i-HOST Docker container when you select eWeLink Smart Home. If it doesn’t appear, refresh the device list in that same location. If it still doesn’t appear, log out and then log in to your eWeLink account. Verify that it now appears. If it does, then check that it’s synchronized. If it isn’t, click on SYNC.
Regards
Hi!
Thank you for answer. After LogOut/LogOn - the SAWF-8P does not appear. May be its happened due to old version docker eWeLink Smart home? Under string “Log Out” in the menu, I see version 2.7.0 ?
Jury
My version is 2.7.3. You must update.
I update docker to 2.7.3 and to see the SAWF-8P.
Big thanks!
Jury
