【Add-on Guide】Adguard Home - Network-wide ads & trackers blocking DNS server
iHost is capable of running an Adguard server, which enables you to have a small adguard local server, possibly enabling other LAN devices to have some ad protection.
Here is how:
  1. Create a volume named adguardhome or similar.
  2. In the add-on list, search for adguard/adguardhome and add it to your local list.
  3. After adding, go to it on the list and click Run.
  4. As Optional settings:
    Network: host
    Volume:
    Host volume: adguardhome, or whatever you created in step (1)
    Add-on volume: /opt/adguardhome
  5. In filebrowser/filebrowser add-on, map the adguard volume to a browse-able folder.
  6. Open filebrowser and edit file adguardhome > conf > AdGuardHome.yaml.
    Change http > address property, choosing a not used port (3001 in my case). The default port 3000 is already used by the add-on itself.
    image image
  7. Restart the adguardhome docker instance.
    After that you can access web ui in http://[ihost]:3001
    (maybe you can run it as bridge and choose which ports to open)
Nice one, thx! :heart:
Since eWeLink CUBE 2.2.0 this Adguard Home image doesn’t work anymore because eWeLink CUBE uses port 53 now :frowning: :frowning: :frowning:
2024-08-29T16:54:25 2024/08/29 19:54:25.350533 [fatal] couldn't start forwarding DNS server: starting listeners: listening to tcp socket: listen tcp 192.168.3.13:53: bind: address already in use
After update 2.2.0 port 53 is apparently in use by eWelink CUBE.
Is there any specific reason for that?
Would it be possible to set if free?
PS: I use it to host an Adblock Home instance from iHost.
Moved your post here and pinged @SuiKa, our dev, for advice.
Thx for your feedback.
53 port is occupied by us.
Can you use bridge network and map the 53 port to other port of your machine?
Yes, I’ve considered that, but the problem is figuring out how to use that alternative port for DNS on other devices.
I mapped port 54 on iHost to port 53 on the container and tried using <IP>:54 as the DNS on iOS and Windows 10, but it doesn’t seem to be working.
Are you monitoring the CPU and Memory usage?
Depending of the size of your blocklists, ADGuard Home will demand a reasonable amount of memory and CPU
