Zero dot minus on NSPanel
@ward My SNZB-02Ps are connected to NSPanel Pro. The temperature readings are reported correctly. However, after updating the firmware in NSPanel Pro to 3.7.x, it looks strange on the NSPanel screen (non-pro), when temperatures are below zero. For some reason the readings are relayed with an error.
Thx for the feedback. A quick ping to @Staff-of-SONOFF
It would be also appreciated if you can tell us more about the error info?
What do you have on mind? There’s no error code. I’m guessing that the negative values passed to the NSPanel are erroneous, or the NSPanel misinterprets them, because perhaps something in the NSPanel Pro firmware has changed and now the syntax is incompatible.
I see thx for the explanation. The issue will be fixed in the upcoming firmware update. As soon as early Feb
The pleasure is all mine :sunglasses:
