Virtual switch
I have just noticed that there is a ‘device list’ in the matter section of the ihost interface.
When I had a look all my physical devices were listed :grinning:. However all my virtual devices were under the ‘more devices’ section with a note – “The following devices are not supported to be added to Matter-supported platforms yet.” :slightly_frowning_face:
Does anyone have a timeframe for this issue?
Also more types of virtual devices would be good – as suggested by the ‘capabilities’ when setting up a VD.
Please share your node information with us of that virtual devices
Agreed! e.g. Energy meter, alarm etc
changing the bulb color and adjusting the brightness
Hi ,
I recently got NS Panel Pro with latest software version. I created a virtual device from Node red. it is visible in split screen but I want to add this virtual device on theme screen. But virtual device is not available in ewelink app. Another issue is if I create virtual temperature sensor, it cannot be used in thermostate configuration page. As all virtual devices are not available in app to configure.
I already have built in sensor on my AC and I have this avaialble in Node red, i just want to expose it to NS Panel so that it can be used for thremostat settings.
Are these limitation of virtual devices or I m doing something wrong.
If these are limiations, I dont see a point of virtual devices and node-red integration if something basic like this cannot be done.
I have the same problem. Will this problem finally be solved?
eWeLink APP from v5.14.0, you can add virtual devices in Home>add device>More Option>Virtual Device page, and you can sync the virtual device to Google Home, Alexa, smartthing to use it!
