Using eWeLink with ESP8266
Hello everyone,
i want to manage my lamps and power stage with eWeLink. So i bought relay switchs and ESP8266. i connected Home Assist and ESP8266 successfully. i created yaml file for this situtation.
But i want to manage my smart relays with eWeLink. i confused my brain in this situation. I want my device to pair automatically with eWeLink. How should i write yaml file for ESP8266 ?
Best Regards,
I remember there have a ewelink add-on for HA, which can sync some HA devices to ewelink, not all of them, partially i think, switches and plugs.
Hello @emrecnulkr ! The best integration I have tested on iHost with ESP8266 is the Tasmota firmware:
https://tasmota.github.io/docs/
The tutorial for Tasmota is here:
https://forum.ewelink.cc/t/add-on-guide-mqtt2cube-tasmota-sync-your-tasmota-devices-to-cube/19413/13
I did a long time ago with the ESPHome, you need to use the NodeRED, but I don“t know if is working yet. The tutorial is here:
https://forum.ewelink.cc/t/ihost-using-esphome-on-nodered-without-home-assistant/18947
maybe you can use this esp module directly:
https://www.aliexpress.com/item/4000078032810.html?spm=a2g0o.productlist.main.5.7c5cc1wWc1wWQn&algo_pvid=8203f279-ac7a-423d-861c-80f9c7d79bba&algo_exp_id=8203f279-ac7a-423d-861c-80f9c7d79bba-2&pdp_npi=4%40dis!USD!7.13!5.56!!!7.13!5.56!%402151e66217115896715113628e6300!10000000202444247!sea!BR!4298515415!AB&curPageLogUid=lEMGMVRZws1h&utparam-url=scene%3Asearch|query_from%3A
the module come with the smart relay firmware and you can use it to build your smart relay product.
