Ewelink virtual devices in iHost
Hi!
Could You please implement the feature in Ewelink Smart home addon to sync Ewelink virtual devices too?
Thanks!
Our product team has plans to implement this feature, and we expect to support it in a version release scheduled for July. Please stay tuned for updates! Thank you!
Additionally, could you describe the specific scenarios in which you envision this feature being used? I will make sure to record your feedback.
For example I use ewelink devices for heating regulation in my house with zigbee thermometers and switches.I turn on heating panel based on room temperature, and there is also a manual override wall switch. In 2 rooms I have an air conditioner too. It has only Alexa and Google Assistant support. I use the air conditioner also for heating, but only when we are not in the room, because it is not comfortable for me. So I want to turn off heating panel when the AC is turned on, and turn it back, when it is off. I cant connect iHost to Alexa by Matter because I dont have echo hub, but I have Ewelink Advanced plan with virtual devices. If I could turn on/off Ewelink virtual device in iHost, it could trigger an Alexa Routine to turn on/off the AC.
It would be also useful to create virtual device in iHost natively without Node-RED, any plans for that?
Cool! Thank you for sharing this user case with us! I confirmed that we will implement this feature. However, it will take a little more time. We expect to have it ready in the next version of iHost.
You mean the 64 bit version of iHost, or the next software version?
No, I mean next eWeLink CUBE Version in June
Hi
any chance to have this in 2026 ?
what are the plans for this?
This feature has been supported since a previous version. You can now also sync eWeLink Linked devices directly to iHost from the Add Device page. Note that creating virtual devices requires an eWeLink Advanced subscription.
Thanks for answer.
I was thinking that I can create virtual devices directly on iHost without using cloud.
This would be something great.
Can you make that possible?
Thank you for your feedback. We have received your request and will conduct an internal evaluation regarding this matter.
Thank you.
