Dear Sir/Madam,
I am writing to request your urgent assistance regarding a critical issue I am experiencing with your Zigbee Bridge Ultra device.
Although the device is connected to the internet via Ethernet and my network is fully stable, the bridge repeatedly goes offline without any apparent reason. There are no connectivity issues on my end—other devices on the same network operate flawlessly. However, the Sonoff Zigbee Bridge Ultra consistently fails to maintain a stable connection.
I currently have approximately 30 Zigbee devices connected to the system, all of which communicate properly. Despite this, the bridge going offline disrupts the entire system and severely affects its reliability.
I previously used an NS Pro device, but I was advised that it could not support the number of sub-devices I have. Based on this, I upgraded to the Zigbee Bridge Ultra. Unfortunately, I am now facing similar—if not more serious—connectivity issues with this device as well.
I kindly request your immediate support regarding:
The root cause of this issue
A permanent and reliable solution
Any necessary firmware updates or hardware-related actions
This ongoing problem prevents me from efficiently using the many devices I have purchased, and it is becoming increasingly frustrating.
I would greatly appreciate your prompt attention and a definitive resolution to this matter.
Thank you in advance for your support.
I would like to share an additional and particularly concerning detail regarding the issue I previously reported.
Interestingly, the Zigbee Bridge Ultra device appears to be powered on (the indicator light is active), and when I access the CAM-S2 connected via the ZB Micro, I am still able to view the camera feed without any issue.
However, despite this, all Zigbee modules—including the ZB Micro—are shown as offline within the application. Furthermore, devices such as the ZB Mini R2 appear to be functioning physically (for example, the connected lights can still be turned on), yet they are also displayed as offline in the app.
This inconsistency between the actual device operation and their status in the application is extremely concerning. It creates a serious security vulnerability, as I cannot reliably monitor or control the system through the app.
I kindly request an urgent explanation and resolution for this issue.
