TRVZB Features Request
Winter is coming and no improvement yet to TRVZB Valves after the long waited hysteresis setting. Here are some requests, let’s hope there’s interest by users and enough votes for ewelink to consider implementing them.
1 - Adaptive Mode/ PID, no more simple on off with hysteresis but good use of valve open/close percentage.
2 - Possibility to link Door Sensor Switches to every single TRVZB Valve to control “Open Window Detection” in the same way we can add temperature sensors to them.
Possibility to select how many minutes should pass between the switch opening and the TRVZB entering the “Open Window Detected”
3 - Add “Open Window Detected” as a trigger even to TRVZB so we can use it to be notified when valves enter or exit, if ever, “Open Window Detection” mode (with or without “Door Sensor Switches” linked to them)
Theese are the ones that comes into my mind at this moment.
Should anyone have any other requests let’s add them here so to have a single thread with requests and votes about TRVZB Valves for our winters.
As I commented earlier, it would be amazing if the TRVZB symbols would turn to bright blue on the NSPANEL Pro once the hearing turns on. I fully support all your points above!
Hello Marco, thank you for your support and suggestions.
We’re currently developing TRV Adaptive Mode, which is now in the testing phase. Once it passes testing, we’ll release this new version.
If you’re interested or would like to try it earlier, feel free to send me your device ID via private message. We can arrange early testing for you and would love to hear your feedback and suggestions to help us further improve the performance of Adaptive Mode.
Can you also try adaptive mode on ihost?
The current test version is only available for the ZBBridge-P gateway environment. Other gateways will be gradually supported after the TRV firmware is officially released.
Regarding the “Open Window Detected” feature request, we’d like to learn more details so that we can further optimize it.
2- Based on the current method, if you create a smart scene that turns off the TRV when the door/window sensor is opened, would that meet your described use case?
3- That’s a great suggestion — I’ll share it with the development team.
I’ve just migrated all of my devices from ZBBridge-P to ZBBridge-U so, as you answered to another user, I’ve to wait for your development to apply to ZBBridge-U.
By the way, my migration was far from “no problem” one. Still waiting for a bug to be solved (I opened a Ticket for it).
2 - It would be far better to have this door sensors linked directly to TRVZBs so that when they trigger “Open Window Detection” TRZVB valves go in “freeze” mode (or off mode) and when windows are closed TRVZB valves turn back to whatever state they were before, AUTO, MANUAL or whatever future new state that would be eventually introduced.
There’s no way as far as I know to memorise last state of a TRVZB Valve to use in scenes to set the valve back to the state it was before “Open Window Detected”.
Two important notes
1- The ideal implementation should allow one single Door Switch to be linked to more than one TRVZB (just like it happens with temperature sensor).
EXAMPLE: One window in a room which has two or more radiators. Both radiators should enter “Open Window Detected” when the window is opened.
2 - The ideal implementation should allow more Door Switches to be linked to the same TRVZB (Every TRZVB should allow more Door Switches to be linked to it)
EXAMPLE: Four windows in a room which has a single radiator (or more). Any of the four windows, when opened, should trigger “Open Window Detected” in the single radiator (or more).
I honestly think that everything would be also “tyeder’ in this way, just as it is with the linked temperature sensors.
Then I will use scenes to use the same door sensors for my ALARM but that is another story.
Thank you for your attention.
@Archarr, please consider adding periodic recalibration. The TRVs losing steps was a major issue last winter for me, this lead to having to manually pull the batteries to have the TRVs recalibrate themselves because otherwise the radiators would not turn off.
I imagine the TRVs losing steps would be a major issue with the so called Adaptive Mode you are working on, as it will cause them to drift.
Two more requests about TRVZB.
1 - I’m using ewelink app in English language and when I edit a TRVZB schedule and I click on + sign (copy schedule menu) I don’t find it clear if I’m copying the current valve schedule TO or FROM the listed TRVZB devices. Is it possible to add a simple “to” to the title so that it becomes “Copy Schedule To”?
2 - Since having the right confort in your house is often a trial and error process, a way to save different TRVZB schedules “to a file” would be very useful so to faster REload a schedule to a TRVZB valve. So one can maybe have different settings for different months/seasons/situations.
Thank you.
My suggestion are
  1. if Zigbee protocol allows let Zigbee T/H sensor to “bind” directly to Zigbee TRV. For example, you can “bind” light switches to light bulbs directly. A hub is still needed to set it up but if it goes offline occasionally it’d still work. Jusy don’t know if battery devices can bind to other battery devices. The idea is it’d help people with weaker sigbee meshes. I bet TRV are often placed at distant parts of the mesh and partly shielded by the metal of the radiator.
  2. Allow third party Zigbee 3.0 T/H sensors if they update frequently enough. I have a few sensors with bigger batteries from before the updated ones with bigger batteries that don’t work.
TRVZB as ROUTER/REPEATER?
I wonder how much more battery will a TRVZB valve consume adding a ROUTER/REPEATER functionality to it?
TRVZB valves operate with 3 x AA batteries, there’s plenty of energy and I would sacrifice battery duration for them to function as a ROUTER/REPEATER. I have one in each and everyone room, ideal situation to expand zigbee net and make it stable (even without the function to extend the number of devices in the net). Moreover, I have my ZBBRIDGE-U and MODEM under UPS and battery power repeaters like TRVZB valves would make my zigbee net trouble free in case of lack of main voltage. Crazy idea? What do you think?
I don’t think this is a good idea. Only devices permanently connected to the mains can function as a router. The batteries simply won’t last the heating season.
Well, if they will last at least one heating season that would be good for me :man_shrugging:
Does this mean that the trvzb will not only switch between on/off whenever temperature pass the configured threshold, so it can learn what valve open percentage is needed for a more stable temperature?
I will report this to R&D and have them evaluate it, but enabling Zigbee routing functionality still poses a significant challenge to battery life.
Yes, once the target temperature is reached, temperature fluctuations will be reduced, making the surrounding temperature more stable.
I just installed 7 Trvzb only to notice they just have the on/off capability at the moment. For me this is a reason to send them back as they overheat the target temperature by a lot. Also the radiator makes quite some noise when fully open.
@Archarr could you give us some insights on how far you are with the development of the version with the adaptive mode?
I’m currently using a conbee II as a coordinator. Any chance that adaptive mode will also work with this when the update comes out? Or is this feature independent of the coordinator anyways?
Best regards Johannes
Another simple but useful feature suggestion.
It would be really helpful having the possibility to change the settings of all the TRVZB added in a group at the same time, in the same way you would change the same setting on a single TRVZB valve.
Practically that would mean adding a “setting” menu in the created “xxx GROUP” of n. TRVZBs similar to the one you find in every TRVZB.
Let’s say I have four valves in a Saloon added in the group “SALOON” and I want to activate “child lock” or “window detection” or any other setting in all of the four valves the best way would be to do it in the SALOON group setting menu.
There is no doubt, PID control has its place in heating (& cooling) systems.
But I fear it is likely not practical in a domestic hot water heating system.
If you consider many domestic heating systems will have a boiler rated perhaps, anywhere between 16 to 36kW. Particularly with older boilers, they may not be able to modulate.
Even some of the later boilers may only modulate 3:1.
So when a room demand for heat is triggered, there maybe two or three radiators rated at 1kW each ‘fired up’, but with a PID controller shutting the flow valves down to little or nothing.
Where’s the 30kW of heat the boiler produces going to go?
It will probably lead to the boiler cycling more than the Tour de France does, for a whole month.
I can’t see it being a practical function, to be honest?
