We still have a problem with the change from summer to winter (standard) time. It does not happen automatically. In order for iHost to set the correct time, you have to force a reboot. Once you do this, the system time will be correct. The implication is that the CUBE system contains a bug. It does not synchronise the time with the NTP server and there is no option to correct manually. This requires fine-tuning.
