Thermostat
Hello i want to use the thermostat to trigger a scene but that doesnt work .why not?
You can select to perform a manual scene or enable/disable auto scene. What’s the situation with your referring “doesn’t work”?
I have a scene were i trigger two sonofs and it does trigger the actuator of the scene but the scene itself doesn’t work but if i trigger the actuator by hand the scene itself doesn’t does work
Could you please provide the screenshots of the scenes?
I'm experiencing the same problem. Have you been able to find a solution? The scene doesn't work when I specify a time range.
Thank you for your help
