Thermo Plugin Suggestion
Hi.
I have two suggestions for the “Thermo Plugin.”
First and foremost, I’d like to request the ability to add more than one device controlled by a single plugin.
I have one thermometer and two radiators in my room, and I’d like them to be controlled simultaneously.
I control the temperature at different times using scenes, and it’s cumbersome to set two separate devices or add devices to the scene twice.
I’d also like to request that the temperature accuracy be increased from +/- 0.5 to +/- 0.1 because in my large room, before the thermometer detects a temperature drop, at a temperature range of 21 degrees +/- 0.5, the temperature fluctuations between 20.5 and 21.5 are very noticeable.
Hello, can anyone answer my suggestions?
Hi, we managed to implement these changes. Check out this thread
I just don’t know when it will be available.
Hey. Is there any update on this query?
It is already available here in a test version.
czy ja też mogę testować ?
Możesz, jeśli napiszesz na forum, że jesteś zainteresowany
Hi. I am also interested in this new feature of thermo plugin.
How it works?
thank you.
Can you please add more schedules than just 7? I need at least 8.
Thx
Could you please add BASIC-1GS as an actuator to the thermo plugin? Also, it should be possible to add multiple actuators to a thermometer or possible to grouping thermo plugins.
Jestem zainteresowany
It’s just a beta test program, you might cause problem at home.
