Thermo Plugin Actuators - Basic-1GS
I use Apple HomeKit at home. I added most of my Sonoff sensors and relays with Sonoff Bridge Ultra. I directly added Matter-supported products and, seeing that the new chip-equipped BASIC-1GS works more stably, I replaced the switches of my underfloor heating valves with them, making them smart. I replaced the wired thermometers in the rooms with Sonoff SNZB-02Ds. While I needed to automate the temperature settings for each room, the Thermo Plugin add-on was released, and due to the number of rooms, I purchased the Advanced package. However, BASIC-1GS cannot be used in Thermo Plugin. I also requested an update through the application, but there has been no update. I think adding this to a virtual device shouldn’t be that difficult.
I solved my problem using the ewelink web interface. Although all Sonoff relays are visible in the web interface, the ewelink app supports far fewer relays. If anyone is experiencing a similar problem, they should configure the Thermo Plugin settings through the ewelink web interface. In fact, creating and configuring the Thermo Plugin through the ewelink web interface is more reliable. A Thermo Plugin I created through the ewelink app was reading the room thermometer reading incorrectly (even though the thermometer showed the correct value in the app).
