The smart plug in Ewelink does not appear as a local device
I have old Sonoff devices, and they show up in the app as local devices, and they work fine without internet.
I recently bought several smart plugs, but they don’t show up in the app as local devices, and when there’s no internet, I can’t use them over the local network.
How can I solve this problem?
I integrated their HomeAssistant, but the smart plugs don’t work there either, without internet.
How can I fix this problem so these devices work over the local network?
coolkit
Software version: 1.3.1
Are these genuine Sonoff products? I don’t recall seeing a model like the one in the picture. It looks like a different manufacturer pretending to be similar in appearance to the Sonoff S61STPF.
This could be a problem, it could be that eWeLink doesn’t support all the features for an unofficial product from another manufacturer.
In the app, you can create a support ticket and try reporting the issue/requesting the model to be added there.
I don’t know if it’s original or not, but the Ewelink works fine, it just doesn’t work over a local network.
I bought it here: https://item.taobao.com/item.htm?id=794893492412&mi_id=0000uuDx6BE0MaoEOr1qT2daa0DzvKEwuitPyiY7KzY5lkw&spm=tbpc.boughtlist.suborder_itemtitle.1.542d2e8deiLPAC
eWeLink supports many different manufacturers, though Sonoff is probably the most popular.
Yours don’t appear to be Sonoff products. They’re at best somewhat compatible with eWeLink. However, many manufacturers sometimes lie about eWeLink compatibility, either not working at all or only partially working.
In your case, it may be that this particular model isn’t fully supported by eWeLink, and that’s why you’re missing this feature, or the devices you bought don’t have it anymore.
The only thing you can do is make sure you have the latest version of the eWeLink app and that your devices have the latest firmware.
Also, create a support ticket through the app with detailed descriptions and device information. They might respond someday, but there’s no 100% guarantee.
From a regular user’s perspective, there’s probably nothing more you can do. You can ensure that your devices are on the same LAN and have seamless communication within the LAN. For this feature to work, the device running the app must communicate with the IOT. Disconnect the internet for a few moments and see if the option appears in the app.
P.S.
The URL takes to the login page.
I’ve already found out that this is a common issue with smart devices running CK-BL602-SWP1-01 firmware.
This is exactly the problem. CK-BL602-SWP1-01(182) and HA - #2 by jam3
I’ll most likely replace the firmware with OpenBeken and integrate it into HomeAssistant. Thanks so much for the replies.
