Are there any plans to improve the SNZB-02P’s ability to create more complex scenes like TH Origin? I mean, for example, introducing the ability to set the differential temperature and/or humidity between other devices as a trigger.
For which platform may I ask?
eWeLink CUBE on iHost or eWeLink app/WEB?
Hi there,
Now I’m interested to eWeLink app/WEB platform, but it would also be worth for the other platforms
Cheers
Raffaele
Is it like a trigger when the readings reach a specific range?
It is a trigger resulting from the comparison of two different TH sensors, in terms of differential temperature value.
For example:
“IF” the temperature difference between TH1 sensor and TH2 sensor is “GREATER THAN” degrees, THAN .
“IF” the temperature difference between TH1 sensor and TH2 sensor is “LESS THAN” degrees, THAN .
I hope this is clear.
The same could be done with the Relative Humidity.
Please note that the TH Origin device is already capable to do this for the eWelink App and Web platforms
Regards
Raffaele
https://a.aliexpress.com/_EIoFkWN
this sensor can do that
Thx for the explanation.
I think such advanced conditions are not natively supported by the eWeLink app at the moment.
You can turn to services like Node-Red for such complex scenes.
The eWelink App already manages the complex scene for the SONOFF TH Origin (THR3xx). Why can’t it do the same for the SONOFF TH sensor SNZB-02?
Regards,
thanks for the advice
