I suggest when TH Elite sensor (or Any Temperature and humidity sensor) is showing data in cast you must select correct Tab by default. What it means? Example, ir your TH Elite has Only Temperature sensor Connected, by default, Temperature Tab should be selected and if only humidity sensor is connected then Humidity Tab is selected by default and if your sensor measure Temperature and humidity you can cresta a largar gadget, to see both data in a single view
Related topics
| Topic | Replies | Views | Activity | |
| Cannot see any of the temperature or humidity levels on cast dashboard | 7 | 352 | July 2, 2024 | |
| Temperatura e umidita....in cast | 0 | 53 | January 15, 2025 | |
| Optimize TRVZB Tiles for eWeLink CUBE | 6 | 199 | October 23, 2024 | |
| Support Zigbee Sensors with soil_moisture cluster for eWeLink CUBE | 10 | 416 | October 21, 2024 | |
| NOd red sonoff temp and humidity sensor | 15 | 748 | May 13, 2025 |
