Temperature and Humidity Reports
Would it be possible to add the temperature and humidity history from the web platform for download as I am having problems downloading this data through the ewelink application
Hi there, may I know your device ID? Actually the history of TH devices could be downloaded via eWeLink web. It’s not possible to download the history from the app right now.
The ID a440011f1d, but how do I get the report through ewelinkweb, because I accessed the device and did not find the option to download the history
There is no option to download this device’s history data, however, we will add it to the to-do list. It may be available in a month. Stay tuned!
Thank you very much PeterGoGo, the application is working, just open eWelink, access the sensor, go to history and click download, in the upper right corner, it generates a .csv file with the correct reading data. In this case, it generated 4395 lines of data, very good. This week I will add the first device with eWelink Remote, I have Wifi, TX, Zigbee models, very good Sonoff devices. Are we going to have outlets with the standard TX or M5 switches?
I think @Daniel_Zhan from the Sonoff team can answer the question of outlet:)
Thank you very much for the information, I will forward the suggestion as soon as possible. PeterGoGo I have a project in mind to automate the gate here at the Condominium for closing and opening the gate, I will use Sonoff devices, as in addition to being very reliable and durable and the service is Top, I would like to see with you if it is possible add a specific command in the scenes part, for example I will use a WiFi relay from Sonoff to activate the radio frequency control or directly on the gate plate, and to have a reference to the open or closed gate I will use a door and window sensor ( DW2-wifi or Zigbee, I’m analyzing it), would it be possible to add a function there in the Scenes part, if it is open for a certain time, it initiates an action as a notification or activates the wifi relay to close the gate?
Hi there, thanks for the idea. We have received similar suggestions and our team is evaluating the feasibility. I will keep you posted when I get more info.
Hello PeterGoGo, thank you very much for your help earlier. I have another question. I am working on some automation projects here in Brazil, and regarding my workflow, I am currently managing about 200 Sonoff device IDs under my main account. I often share these devices with other Sonoff accounts that I create for clients, allowing them to use the web platform to access and control the devices.
The reason behind this approach is that many of my clients are not tech-savvy and need assistance with configuration, such as changing the schedule for turning lights on. In these cases, I make the adjustments for them. Is this workflow correct, or does Sonoff plan to introduce an enterprise platform for these types of solutions?
Also, I would like to congratulate Sonoff on its high-quality products. I have several automation setups where there is a high volume of activations, ranging from 18,500 to 23,300 per month. I hope this makes sense.
Kind regards
Here I cue @Teki for further discussion, know your requests better and make a evaluation if possible.
Recently we’re developing new tools on eWeLink WEB, the upcoming one is Timer Management, the device Schedule & Timers will be available on eWeLink WEB, in the coming update you’ll be able to view the daily schedules or timers. Management (create/edit/delete) in batch may be available in following update.
Another tool we’re planning is the Sharing Management on WEB, users can manage the Home Sharing or Device Sharing on eWeLink WEB, you may be able to add or remove users, change access duration, etc.
Will these help? if you have any ideas or needs, please let us know.
