Tailscale offline
Merhabalar tailscale sık sık offline oluyor yardımcı olur musunuz günlük de yazanlar aşağıda şimdiden teşekkürler
2025-04-11T15:40:48 2025/04/11 12:40:48 magicsock: [warning] failed to force-set UDP read buffer size to 7340032: operation not permitted; using kernel default values (impacts throughput onl
2025-04-11T15:40:48 2025/04/11 12:40:48 magicsock: [warning] failed to force-set UDP write buffer size to 7340032: operation not permitted; using kernel default values (impacts throughput on
2025-04-11T15:40:48 2025/04/11 12:40:48 onPortUpdate(port=37067, network=udp4)
2025-04-11T15:40:48 2025/04/11 12:40:48 magicsock: disco key = d:2526b32394435928
2025-04-11T15:40:48 2025/04/11 12:40:48 Creating WireGuard device…
2025-04-11T15:40:48 2025/04/11 12:40:48 Bringing WireGuard device up..
2025-04-11T15:40:48 2025/04/11 12:40:48 Bringing router up…
2025-04-11T15:40:48 2025/04/11 12:40:48 Clearing router settings..
2025-04-11T15:40:48 2025/04/11 12:40:48 Starting network monitor…
2025-04-11T15:40:48 2025/04/11 12:40:48 Engine created.
2025-04-11T15:40:48 2025/04/11 12:40:48 pm: using backend prefs for “profile-c4d2”: Prefs(ra=false dns=false want=true ssh=true webclient=true routes=[0.0.0.0/0::/0 192.168.1.0/24] snat=trı
2025-04-11T15:40:48 2025/04/11 12:40:48 logpolicy: using system state directory “/var/lib/tailscale”
2025-04-11T15:40:48 2025/04/11 12:40:48 got LocalBackend in 60ms
2025-04-11T15:40:48 2025/04/11 12:40:48 auditlog: created
2025-04-11T15:40:48 2025/04/11 12:40:48 Backend: logs: be:12ce1aeadaea385c9bfba093529565bf038aa6067f49f573134d586d6d744cc2 fe:
2025-04-11T15:40:48 2025/04/11 12:40:48 control: client.Login(0)
2025-04-11T15:40:48 2025/04/11 12:40:48 health(warnable=warming-up): error: Tailscale is starting. Please wait.
2025-04-11T15:40:48 2025/04/11 12:40:48 control: doLogin(regen=false, hasUrl=false)
2025-04-11T15:40:48 boot: 2025/04/11 12:40:48 Running 'tailscale up
2025-04-11T15:40:48 Error: changing settings via ‘tailscale up’ requires mentioning all
2025-04-11T15:40:48 non-default flags. To proceed, either re-run your command with -reset
2025-04-11T15:40:48 use the command below to explicitly mention the current value of
2025-04-11T15:40:48 all non-default settings:
2025-04-11T15:40:48
2025-04-11T15:40:48 tailscale up -accept-dns=false -advertise-exit-node -advertise-routes=192.168.1.0/24 -ssh
2025-04-11T15:40:48
2025-04-11T15:40:48 boot: 2025/04/11 12:40:48 Sending SIGTERM to tailscaled
2025-04-11T15:40:48 boot: 2025/04/11 12:40:48 failed to auth tailscale: failed to auth tailscale: tailscale up failed: exit status 1
2025-04-11T15:40:48 2025/04/11 12:40:48 tailscaled got signal terminated; shutting down
2025-04-11T15:40:48 2025/04/11 12:40:48 control: client.Shutdown…
