Cant run Tailscale on my iHost. Running iHost SW v1.9.1. Tailscale installation goes OK but when press Go to Tailscale button i always get this:
Failed to connect to local Tailscale daemon for /localapi/v0/status; not running? Error: dial unix /var/run/tailscale/tailscaled.sock: connect: no such file or directory
I’m having the same error. I posted the details here:
This is a known issue, and after troubleshooting it was initially determined to be:
There is a problem with the web client module in the Tailscale v1.48.0 image package released by tailscale on August 16, 2023, which prevents the web ui page from opening properly.
We are waiting for tailscale to release a new version.
Thank you for your feedback. Lets wait and see.
The same problem, waiting from middle august
@edimarcr @aslak.siira @RobertoGonzalez
Hi, Tailscale will release the new update soon, before that, you can try the temporary method:
When you start the Tailscale add-on, go to its log page and find the authenticate link, visit the link to connect the tailscale service.
