[Suggestion] Log of devices that have been removed IHOST
Please enter a register of devices that have been removed.
  • After removing the device from Ihost we lose the entire history of the device.
  • we have no access to graphs, device logs,
  • we lose scenes in which the device participated.
If a device is deleted, it should be moved to the DEVICES REMOVED folder.
The scene with this device should be deactivated and saved as NEEDS EDIT.
In the Deleted Devices folder, selecting the deleted device will allow you to view the device logs and graphs.
If we add a device to Ihost again whose ID is in the registry of deleted devices, it should be possible to restore the entire device history.
Of course, to limit the growth of the log file, you need to add the ability to manually remove the device from ihost memory.
