Good evening.
Maybe someone faced the same issue before…I have a Sonoff ZBmini R2 intended to control my lights outside. I set an On-Off timer with everyday frequency as you can see in the picture below.
Unfortunately I noticed that sometimes it stops working and I have to reset the timer to make it work again. Checking the logs can be seen that the timer actually works but 1 second later the status changes back by itself.
I believe that this happens mostly after a power outage occurs but not sure if limited to this kind of occurrence.
Can you please let me know your thoughts?
Thanks.
