SONOFF SNZB-06P24 – Great features, but could the detection interval be improved?
First of all, I would like to congratulate the SONOFF team on the SNZB-06P24. After testing the device, I believe it has several excellent features that deserve recognition.
  1. Multiple mounting options: I think this is a great decision, as it allows users to choose the most suitable installation method for their particular needs.
  2. Detection area adjustment: This feature works perfectly and allows the detection zone to be adapted to the environment.
  3. Calibration: An excellent feature that really helps eliminate false or phantom detections, improving the sensor’s reliability.
  4. Sensitivity adjustment: Another useful option that allows users to fine-tune detection performance according to their needs.
  5. Installation assistant: The step-by-step guidance makes installation and configuration much easier and more comfortable for users.
However, there is one aspect I believe could be significantly improved: the 15-second detection interval.
In my opinion, 15 seconds is too long, especially when compared with some competing products.
One of the main purposes of these sensors is to automate lighting, improving convenience while also reducing energy consumption.
For example, when someone enters a room, the sensor activates the lights automatically. However, if the room becomes empty, having to wait 15 seconds before the sensor can report that no presence is detected can result in unnecessary energy consumption, particularly in areas with frequent, short visits.
My suggestion to the SONOFF development team is simple:
Have you considered reducing the minimum detection interval from 15 seconds to 5 seconds, perhaps through a future firmware update?
Even better, allowing users to select between 5, 10, and 15 seconds would provide greater flexibility depending on their automation needs.
I believe this relatively small improvement could make an already very good product even more competitive.
Congratulations again on the excellent work, and I hope the team will consider this suggestion.
Best regards!
Of course, I don’t want to challenge your opinion, but if we’re talking about a single room with 40-watt lighting, the annual consumption—based on a 15-second activation duration—comes to roughly 6 kWh. Naturally, this depends on the country you live in and your specific electricity tariff, but for me, it works out to around 50–60 CZK (roughly 2 to 2.20 EUR) per year. Personally, I set these intervals to between 60 and 120 seconds; this helps prevent false negatives (where the system thinks the room is empty when it isn’t) and also helps preserve the light sources—which are subjected to high inrush currents during startup—as well as the switching component itself.
I understand your point, and I agree that frequent switching can affect certain lighting systems. However, I would like to share my own experience.
I have LED lamps that have been working for approximately 14 years without needing replacement. In my experience, good-quality LED lighting can last a very long time, even with regular switching.
I also have a Wenzhi radar presence sensor configured with a 5-second interval, and it works extremely well, without causing any noticeable problems.
On the other hand, I have noticed that the SONOFF SNZB-06P24 sometimes takes up to 25 seconds to report the absence of presence, which I consider excessive for certain automation scenarios.
I agree that the energy savings from a few seconds may seem insignificant in a single room. However, when you have multiple sensors and lights throughout a house, those unnecessary seconds add up.
But my main point isn’t just about energy savings. It’s about flexibility and giving users the freedom to configure their devices according to their needs.
If you prefer 60 or 120 seconds, that’s perfectly reasonable for your installation. But why shouldn’t another user be able to choose 5 seconds if their installation works perfectly with that interval?
I’m not suggesting that SONOFF should force everyone to use 5 seconds. I’m simply asking them to offer that option.
After all, having more configuration options is an advantage, not a disadvantage.
I think @spoustaml raises a very valid point regarding the lifespan of lighting sources and switching components. Frequent switching can accelerate wear on relay contacts and LED driver electronics. If this leads to premature replacement of a bulb or switching device, the replacement cost can easily exceed several years of electricity savings. There is an environmental cost associated with manufacturing, transporting and disposing of replacement equipment.
Let’s consider a 40 W light and compare 5 seconds with 60 seconds. Even with 20 activations per day, the theoretical maximum annual saving is only around 4.5 kWh, or approximately €1.35 at €0.30/kWh.
We should also remember about Zigbee network traffic. Frequent presence/absence changes generate additional reports and radio activity. One sensor is unlikely to matter much, but several sensors can create unnecessary traffic across the network.
I’m not saying everyone should use long timeouts. Different installations have different needs. However, I believe a reasonable balance between responsiveness, equipment lifespan, network traffic and energy consumption is more important than switching lights off a few seconds earlier. Saving energy makes little sense if achieving those savings means unnecessarily shortening the lifespan of the equipment.
I understand your arguments about energy savings and equipment lifespan, but I think we’re mixing up two different concepts: presence detection time and lighting switch-off delay.
First, regarding Zigbee traffic, if the sensor only reports state changes, the number of messages is essentially the same whether the absence detection interval is 5 or 60 seconds: one message when presence is detected and another when absence is detected. The difference is when the second message is sent, not necessarily the amount of network traffic.
Of course, a shorter interval could generate additional reports if detection is unstable, but that is not an inevitable consequence of using 5 seconds.
Second, detecting absence after 5 seconds does not mean the lights must switch off after 5 seconds. Using an automation system such as Node-RED, you can detect absence immediately and configure the lights to switch off after 30, 60 or 120 seconds, cancelling the timer if presence is detected again.
Therefore, faster detection does not necessarily mean more switching cycles or shorter equipment lifespan.
Regarding LED lifespan, I have LED lamps that have been operating for approximately 14 years without replacement. Quality certainly matters. I also use a Wenzhi radar sensor with a 5-second interval, and it works extremely well.
Meanwhile, my SONOFF SNZB-06P24 sometimes takes up to 25 seconds to report absence.
I agree that the financial savings in a single room may be small, and your energy calculations are reasonable. However, my request is not exclusively about saving electricity.
My point is simple: why limit the user to 15 seconds when a configurable 5-second option would provide greater flexibility?
Those who prefer 60 or 120 seconds could continue using those settings. Those who need faster detection could choose 5 seconds.
I believe giving users more control over their devices is an improvement, not a disadvantage.
This is simply a discussion where we are exchanging opinions and different points of view. I think it’s great that everyone can share their ideas and experiences, even when we disagree. That’s precisely what makes a forum valuable: hearing different perspectives, learning from each other, and having a constructive debate. We don’t all have to agree to have a good discussion. :wink:
