Sonoff CAM-S2 + TV streaming
Hello
Does enyone tried to stream from CAM-S2 to the TV?
I think it is not possible to have this done directly on TV, unless using www browser but each time it would be long and tiring process…
I have a linux-based digital satelite decoder with ability to edit the channel list.
I can add a streaming-based chanel to my list (I was thinking of CAM-S2) but will it be possible to watch my camera as a normal tv channel :stuck_out_tongue:
How can I get this link with live streaming?
Can I use RTSP (will it work?) or maybe there is another way?
I`ve heard RTSP is just local and I have to be in the same local network… is it true?
Artur
I’m using but with Apple HomeKit. I have the camera integrated with Home Assistant with a bridge to HomeKit.
Problem solved… it is doable using free of charge “tailscale” app
I can watch live camera view from different location on my home tv :star_struck:
Details for those who are interested… :upside_down_face:
Sonoff Cam-S2 is placed in basement and connected to Huawei Mate 20 lite (android with sim card as hotspot). No root device required. Tailscale app instaled on hotspot from google store and connected to tailnet using google account. Subnet routing set and confirmed in tailscale app - required.
Octagon SF8008 (linux, Enigma2, ATV7.6) - satellite decoder placed and connected to my home wi-fi network. Tailscale installed using PUTTY / SSH and live stream video link added to program list using dremboxedit.
Link to stream for You channel list:
rtsp://[user]:[password]@[adres_IP]:[port]/[path]
*user - account name in RTSP tab eWelink app (default: rtsp)
*password - password RTSP set in eWelink app (default: 12345678)
*adres_IP - adres of Your camera connected to hotspot
*port - default: 554
*path - “av_stream/ch0” or “av_stream/ch1” for lower resolution
You can generate Your own link in eWelink app in camera settings
Maybe someone will find it useful :upside_down_face:
I use wireguard to connect to the local network and I have vlc on my devices (and tv) and it works great.
Cool. And what about the camera quality? Is it worth buying? Do you use the cloud or just a card? What’s the quality of the night/dark recordings?
In my opinion it is worth buying…
I`m using only sd-card for now, but working on 24/7 loop recording via talescale :slight_smile:
Picture quality in my basement in the night (complete darkness) looks like this :slight_smile:
It looks decent. :slight_smile:
Can leg be unscrewed? Have you tested multiple simultaneous transmissions? I’m curious how the camera reacts to more than one connection.
It’s a shame Sonoff didn’t make a fully POE camera. Especially an outdoor version.
If You mean watching at two different devices at the same time? No I didn`t test it…
I think it is not possible as You can be unfortunately logged in only at one device at the time…
I will try to watch my camera on the phone and tv screen later today and let You know… :slight_smile:
Exactly… two simultaneous views. :slight_smile:
If it’s not possible, that’s a huge drawback of this camera.
If that’s not a problem, check how the camera saves the stream to the card. Is it one large file or periodically?
I’m also curious if it’s possible to watch old recordings directly from the card in the camera, or are we forced to do so by a paid camera plan?
Anyone using the Camera Plan?
Do I understand correctly that they’re asking for $19.99, and I have to pay $9.99 for Advanced separately?
Almost $30… wtf!
Good for you, you get it. I’ll get an SD card and get their advanced camera plan for free.
Hmm… I don’t think I quite understood. Free?
Share details with us :slight_smile:
Leg can`t be unscrewed, at least I couldn`t do it… Perhaps using more force would have allowed me to unscrew the leg, but I was afraid of damaging it. The safest thing would probably be to open the camera itself first and make sure that the leg is not a permanent part of the housing. I’m not sure, though, if it can be opened. How would you want to mount it later if the housing is rounded and the USB-C port is on the back?
I made 3 simultaneous connections:
  • phone (Samsung S25FE, android, eWelink app)
  • tablet (Samsung A9+, android, eWelink cast)
  • tv via satellite decoder (Octagon SF8008, linux, Enigma2, tailscale)
all devices showed the same image without any disruptions but tv had a delay for about 2 seconds
Just keep in mind that the image my camera showed is static… it’s possible that if I watched moving material at the same time, there would be distortions.
I only have a few small files because the camera doesn’t record continuously. In my case, when I enter the basement, the recording starts and ends a few seconds after I leave it. Recording and file size depends on how long the event lasts…
I don`t have “camera plan” so I can`t watch recordings via my phone… I have to remove sd-card from camera and place it into another device, e.g. tablet (very inconvenient).
That’s why I started the preview through the satellite decoder on my tv to try recording the footage directly to the hard drive. The downside, however, is the constant data transfer, which quickly consumes the available GB (in my case prepaid phone as hotspot with internet package). The next step would be to record only the triggered events… :slight_smile:
Thanks for all the information! :slight_smile:
However, I think I’ll have to look for something else, because the lack of a preview of saved video is a serious problem.
I’m a bit puzzled by how they designed the user model for these cameras… Without additional storage, this camera is a bit of a dud. The only thing it provides is the current image and a possible archive if you remove the SD card.
Cameras this weak were manufactured 15 years ago, and they’re still making them in 2025/26. It seems like from the start they wanted to force you to buy a plan and rip you off.
It’s a bit absurd how limited this camera is without a paid plan. It actually lacks the typical full functionality of modern cameras.
I understand that they can offer a paid plan that offers a few extras, like cloud storage or access to the camera via their servers from anywhere, but the lack of basic features is absurd.
If the standard option doesn’t include full control over what’s recorded, then… Without a dedicated NVR solution, the camera is a crippled device that only transmits images and nothing more. In such a case, the purchase’s value drops to almost zero.
I totally agree with You…
If you agree to store your private materials (video recordings, photos) in the cloud, you pay extra for this convenience. On the other hand, I am against this solution. I can`t imagine my private “things” being stored elsewhere, so I bought an SD card to have my recordnings locally. I also expect access to them as basic function without having to move the card between devices.
Exactly.
I’m also not comfortable with storing video/audio from a camera in the cloud. Although there are probably people who don’t care about it, and that’s fine… but for others, like us, the lack of local functionality is a bit of a problem.
The usage model for these Sonoff cameras is quite strange. The fact that you can’t watch already saved video directly from the camera is a technological shortcoming. This shouldn’t happen in 2026.
Cameras these days are just small computers, usually running Linux, and the hardware performance is quite high. So the lack of such basic features is a joke. :slight_smile:
A Sonoff camera is essentially a simple camera that sends an RTSP stream, and the user has to create everything else themselves… or pay for the cloud.
Not so great when I only want one camera that won’t have internet access, but will save to the SD card and preview the recording over LAN… Sonoff isn’t suitable for such a model. :slight_smile:
