I have zigbee hub pro version and temperature/humidity sensor and thermostats.
idea I want to control each room temperature based on temperature sensor not on thermostat temperature sensor
- If room temperature below > turn thermostat to xx degrees
- If room temperature abow > turn thermostat to xx degrees
In web version I see “Scene not supported”
when this will be fixed? Is there workaround this?
Is it the same if I use other platform - that I can control thermostat based on room temperature from zigbee temp/humd. sensor?
