Siri Shortcut from iOS 17.2
Hi, all.
From iOS 17.2 I have problem with shortcut created and added to Siri.
Now Siri, after the name about created command return web result search and doesn’t look into saved shortcut…any idea/help?
Hello, please make sure you have created the correct command name in the eWeLink App, it may take a few minutes for the command to take effect after you save it.
You think with 17.2 something change?
Before all run ok.
I see now I have to tell: ehi Siri, Comando rapido. Siri answer: witch comando rapido you want?
I tell the name and iPhone execute.
Before was enough direct the name
Marco Serra
Cell.: 3356427300
