The scenario I set from the Ewelink application does not work, but the same scenario works at ihost. For the first time I encountered such a situation. What do you think is the reason for this?
They are two different systems, with slightly different logic in scenes. Can you tell us more about your configs?
Do you happen to be this case? A patch is coming to resolve this issue
The worse is that if you write any new scene to work for a limited period of time, it doesn’t work at all. It only works if it’s work all day! It’s a very strange befavior that i noticed from two or three days ago!
After the latest Zigbee Bridge Ultra update, the issue has been resolved.
