RF bridge improve
As said before, RF bridge is perhaps the best device tou have, and you should to improve it.
Now only ONE sensor attached to RF bridge can act a trigger. If I have varoius sensors (EX: mov sensor) that executes an action, I have to do a scene for each sensor. More easy would be if sensor 1 OR sensor 2 OR sensor 3 (all attached to the same RF bridge) THEN… Please you have to improve this
I doubt that such a change will ever be introduced.
MOST IMPORTANT IMPROVING TO RF BRIDGE IS POSIBILITY TO USE MORE THAN ONE SENSORS ATTACHED TO RF for creating scenes. This will simplifyy a lot programming.
IF sensor 1 OR sensor 2 OR sensor 3 THEN … IN ONE SCEN. PLEASE EWELINK TEAM LISTEN
I do not understand why not implemetentig this
If sensor 1 then … turn on bulb 1
If sensor 2 then… turn on bulb 1
if sensor 3 then… turn on bulb 1
If sensor 1 OR sensor 2 OR senssor 3 then … turn on bulb 1
In this way things are MUCH EASIER
Whit a few scenes everything can be done
This is a request for more about the app scene feature?
Multiple triggers in scene, right?
Right
But I only can enter ONE trigger from an RF BRIDGE
Imagien I want to turn ON SONOFF WIFI BULB when ONE of these RF door sensors is activated:
If sensor 1 (attached to RF1) then turn on bulb 1
If sensor 2 /attached to RF1) Then turn on bulb 1
etc.
I have to made an scene for EACH sensor.
If this IOT system works on CLOUD, I think is much easier to create ONLY ONE SCENE for all these sensor attahced to the SAME RF BRIDGE
This would not be a problem: Would simplify A LOT
IF sensor 1
OR sensor 2
etc. (all attached to the same RF bridge)
THEN…
Please IMPLMENTE IT: I do NOT want new features. I want GOOD WORKING and EASY WORKING
If I can make a suggestion, I would recommend imitating the MacroDroid model in terms of trigger, action, restrictions…
MacroDroid actually does most of what people couldn’t achieve with ewelink. Multiple triggers per macro/scene… etc.
IFTT macrodoid… What I suggest is neccesary ans easy to understand. ewelink has to be easy and funcional
Multiple trigger support would be a feature request, and it has been under discussion.
But we can not guarantee it will come, it depends on the results of the product team’s evaluation as such changes in our cloud could be messy.
You already have multiple trigger support for creating a scene, but from different devices. As you know RF bridge can have multiple devices attached
It is as easy as enabling RF bridge act as trigger more than one time.
I do not know what can happen in cloud. I think cloud will work better because number of scenes will be less. RF bridge is perhaps the best device your IOT has… And you can attach 16 sensors to it… but onlyy ONE can act as a trigger. I think you have to update it
