Improve RF bridge
If sensor 1 then… If sensor 2 then… But if these RF sensors are in the same RF bridge, ONLY ONE can be selected and I have to create a separate scene for sensor.
If you enable being able to choose MORE than one sensor, scenes would be less and easier
If sensor 1 OR sensor 2 or… THEN
The same limitation exists with their other devices too…
my use case - if iFan light is on, and temp is above x… switch fan to whatever level…
but if I have the fan light selected as one of the scene conditions, I cannot select the actual fan speed, and vice versa if I first populate the fan speed before trying to select the light as part of the conditions. Its frustrating and makes creating scenes needlessly complicated, messy, and frustrating.
