👨‍💻‍【Release Note】eWeLink CUBE V2.5.1 Update
This is my indignation. When you have more than 20 devices at home it’s a pain to re-pair every time you update the system. Imagine this situation in a security system or medical equipments. How they can do software updates without mess all ? Sonoff could invest more in software testing.
Yes, every time I send feedbacks with logs, printscreens and all information that could help.
Most likely that is why you receive new versions that are not officially published.
Hey, massimo, may I know the device model?
I don’t think so, I’m a normal user, I just bought the product as soon as it was released.
models are two and they both have the same problem
QS-Zigbee-C01
QS-Zigbee-ECC02
immagine
immagine
Thank you for let me know, had a discussion with our engineer and learned that not all of the Brands or Manufactures following the same ‘ON’/‘OPEN’ or ‘OFF’/‘CLOSE’ commands send to the device, so we are evaluating a ‘reverse toggle’ add to the control UI page as a work around.
Hi Songal,
I have updated to 1.13.0 few days ago…
But this does not seem to fix the issue of name loss. Or maybe it does but my issue then is different?
I have lost all my devices in Alexa twice already, now that I’m on 1.13.0
It happens for no reason (no FW update, nor iHost reboot).
In Alexa, on the sudden, all devices disappear, and then reappear few minutes later, with their names changed to the original long string (device ID). And I have to re change them again…
So just to make sure, the 1.13.0 is intended to fix those devices loss in Alexa, through Matter Bridge?
Thx
Can you submit your syslog to me again via the help center?
Hi Teki - seeing the release notes of the latest releases is useful but it would be great if you could publish a table of known issues with a corresponding status / anticipated release of resolution. Please can this be published for Cube/iHost?
Hello :slight_smile:
I tried several times to download the log using this:
But every time the download starts and get stuck to 0%
I checked if I had any popup blocker or antivirus whatsoever , but nothing like that…
So I do not know how to get that log file out…
Try downloading with Chrono Download Manager disabled.
Thx. :+1:
The original chrome download manager was flagging this download as unsecure and blocking it. But there was no mention of that in the Chrono download manager.
Got it :slight_smile:
Done let me know if you got it. Thx
The pleasure is all mine :wink:
Matter is still in experimental phase. Both in iHost and in Alexa platform. Expect anything.
Are those devices of yours all Zigbee ones?
Yup, all of them (25+)
Quite tedious to rename everything, every now and then… :slight_smile:
But still, I’d like to keep iHost as my low level controller for all Zigbees …
I could re-pair everything on Alexa, (Echo Studio) but I do not like the Alexa App… I prefer the Web server of the iHost :slight_smile:
If you prefer iHost, then you have to live with it for now. I believe that some improvements and fixes are coming soon.
Yes :slight_smile: I know.
My wife does not understand the beauty of beta testing…
Personally; it does not bother me that much, I know it’s gonna stabilize at some point :slight_smile:
Hi, I’m curious, how were you able to pair Alexa and Google Home together in iHost? :slight_smile:
