【Release Note】 Zigbee Bridge Ultra Stable Version History
v2.10.0(2026/11/10)
New Features:
- Eligible SONOFF TX series switches in Motor Mode can now be exposed to Matter-enabled platforms via Matter Bridge, with open, stop, close, and position controls.
Optimizations
- More settings are now available in eWeLink App v6.0 for the following Zigbee sub-devices:
- SONOFF MINI-ZBRBS: Added a one-button control option for Pulse Mode.
- SONOFF ZBMINIL2: External Switch Mode can now be changed.
- SONOFF MINI-ZB2GS: Power-on State now includes a Toggle option.
- Improved response times when controlling devices synced to Apple Home via Matter Bridge after a ZBBridge-U restart.
- Updated SONOFF’s official compatibility reference with the latest supported devices and Matter Bridge capabilities.
Bug Fixes:
- Fixed an issue where Smart Security status could fail to update on Matter-enabled platforms or Home Assistant when arming or disarming was triggered by a Smart Scene.
- Fixed a bug where the ZBBridge-U alarm could continue sounding after a factory reset was initiated.
- Fixed an issue where local scenes using SONOFF SNZB-02M air pressure as a condition could fail to trigger when the set threshold was exceeded.
- Fixed an issue where temperature and humidity readings from the selected external sensor for SONOFF SNZB-02UL could fail to display after the sensor was reselected.
- Fixed an issue where some Zigbee sub-devices showed an available update in the Local Web Portal but could not be updated.
