【Release Note】 Zigbee Bridge Ultra Stable Version History
v2.6.0(2026/09/10)
New Features:
- Added device support for SONOFF TP-WGZBA Zigbee/ Bluetooth dual-mode thermostat panel.
Optimizations:
- SONOFF BASIC-ZB1GSP now supports bi-directional energy monitoring, with exported energy data available in history graphs.
- SONOFF SNZB-02UL can now use SNZB-02D, SNZB-02P, SNZB-02WD, SNZB-02LD, SNZB-02DR2, SNZB-02B, SNZB-02M, and other SNZB-02UL devices as external sensors, providing more accurate room temperature measurements.
- The Ethernet MAC address is now available in the Local Web Portal.
- SONOFF SNZB-03PR2 can now be used as a Smart Security alarm trigger.
- Automations now run immediately after creation or editing if their sub-device trigger conditions are already met.
- Updated BTHome device mappings over MQTT to represent supported capabilities more accurately.
Bug Fixes:
- Fixed an issue where ZBBridge-U could continue beeping when delayed arming was enabled with more than three sub-devices.
- Fixed an issue where Zigbee device syncing to Home Assistant could fail after MQTT recovered from an initial connection failure.
- Fixed an issue where SONOFF SNZB-09P was shown as Unsupported and could not be exposed to Matter-enabled platforms via Matter Bridge.
- Fixed an issue where the SONOFF SNZB-06P24 Presence Sensor reported illuminance values too frequently.
