【Release Note】 Bridge-U | Zigbee Bridge Ultra Stable v2.0.2/v2.0.1/v2.0.0 Update
:blue_book:【Release Note】 Zigbee Bridge Ultra Stable Version History
v2.0.2(2026/06/26)
New Features:
  • Expanded Device Compatibility: Added support for SONOFF MINI-ZB1GP / MINI-ZB1GSP single-channel Zigbee smart switches with electricity monitoring.
  • Home Assistant Audio Automations: Added support for playing audio from Home Assistant through the ZBBridge-U speaker, enabling audio-based automations.
  • Expanded Matter Hub Compatibility: Now supports syncing bridged dimmable lights along with the Matter Bridge when it is added to ZBBridge-U.
Optimizations:
  • Firmware Recovery Improvement: Improved the factory reset logic for better performance and stability.
  • Matter Bridge Update: Now supports syncing Boost Mode from SONOFF TRVZB to third-party Matter platforms.
  • Matter Sync: More Wi-Fi devices can now be synced to Matter-enabled platforms, including:
  • CoolKit CK-BL602-TC-01 (216) gate operator
  • CoolKit NON-OTA-GL (272) eWeLink thermo plugin
Bug Fix:
  • Fixed an issue where SONOFF SNZB-02M could incorrectly show air pressure comfort as out of range when no air pressure comfort range was configured.
v2.0.1(2026/06/18)
New Features:
Bug Fix:
v2.0.0(2026/06/09)
  • Added support for SONOFF SNZB-03PR2 Zigbee motion sensor with illuminance reporting.
Optimizations:
  • SONOFF SNZB-02DR2 now supports using SONOFF SNZB-02M and SNZB-02B as external sensors for more accurate room temperature readings.
  • Improved support for metering capabilities on Zigbee single-channel smart plugs with energy monitoring.
