【Release Note】 Bridge-U | Zigbee Bridge Ultra Stable v2.8.0 Update
:blue_book:【Release Note】 Zigbee Bridge Ultra Stable Version History
v2.8.0(2026/10/13)
New Features:
  • Added support for the following Zigbee devices:
    • SONOFF SNZT-04P Zigbee door/window sensor
    • SONOFF SNZT-03P Zigbee motion sensor
    • SONOFF ZBM5-1C-86/120 Zigbee smart wall switch
    • SONOFF ZBM5-2C-86/120 Zigbee smart wall switch
    • SONOFF ZBM5-3C-86/120 Zigbee smart wall switch
  • Added five selectable alarm sounds configurable for the SONOFF SNZB-09P indoor siren.
Optimizations
  • Improved the process for entering pairing mode and performing a factory reset on the SONOFF SNZB-02B.
  • SONOFF SNZB-02DR2 can now use two external sensors, with temperature and humidity readings from both shown on its display and in the eWeLink App.
  • Turbo Mode is now available in the Local Web Portal to maximize the Zigbee module’s transmit power and help improve signal strength.
  • Added support for the Tuya T2-Z62 smart fan switch, with supported controls exposed to Matter-enabled platforms via Matter Bridge.
Bug Fixes:
  • Resolved an issue preventing a SONOFF TR-WGZBA thermostat panel from working with two SONOFF TRV-ZBT thermostatic radiator valves at the same time.
  • Fixed an issue where the SONOFF TR-WGZBA could incorrectly display 0°C when linked to a SONOFF SNZB-02DR2.
  • Fixed an issue where the operating mode and target temperature for the Atlantic Group Interface Naviclim (GW003-AS-IN-TE-FC) were not displayed in the eWeLink App.
  • Fixed an issue where the alarm status of the SONOFF SNZB-09P could fail to sync after the bridge recovered from a power outage, leaving the alarm controls in the eWeLink App unresponsive.
  • Fixed an issue where sub-devices could disappear or lose their names in the eWeLink App after an offline ZBBridge-U was deleted and re-added to the same account.
  • Fixed an issue where the thermostat mode and operating status of the MOES BHT-002 were not displayed in the eWeLink App.
This is not possible!
I updated and it does not show two temperatures from different external sensors.
I have one per stay and I can only add an external sensor.
