Dear Team, I have some suggestions for devices that I’m missing and would like to see:
SONOFF Orb Socket Smart European Wall Socket (WS01TPF-E), but in a Zigbee version
SONOFF Orb Socket Matter Over WiFi Smart European Wall Socket | WS01TP
Please let me know if you’re considering a Zigbee version -
I’d like to see a 4-channel SONOFF Zigbee switch with features similar to the 4CHPROR3 (it doesn’t need to have a 433 MHz remote control)
The features that are important to me are dry contact, DC power, adjustable interlock mode, and inching mode. The design could be more compact than the 4CHPROR3—for example, something like this:
https://www.aliexpress.com/item/1005006365663674.html -
Tank Water Level Sensor
Most manufacturers produce ultrasonic level sensors. However, I’ve had very good results with the Hydrostatic Water Pressure Level Sensor:
https://www.aliexpress.com/item/1005005848308192.html
I know this is probably unrealistic, but I would welcome a device with an analog input (either voltage-based or directly for a 4–20 mA current loop). Application features:
- calibration of the lower and upper water levels (and the ability to set the water volume)
- The tank can have various shapes (such as a horizontal cylinder), and the increase in water volume may not be linear with respect to the level height; therefore, it would be ideal if the application allowed for some form of volume calibration based on level height (e.g., in 10% increments).
I would greatly appreciate it if you could consider my suggestions. Have a nice day, Jan
