Personally, I’ve got 30-odd eWeLink devices.
I’d love to control some of them from my watch - but the WearOS app isn’t compatible with one of the largest manufacturers of WearOS devices?
“Your device isn’t compatible with this version”
I don’t have any real need for any of the other ‘Prime’ plan attributes. Seems odd that - if you’re a Galaxy Watch user, you’re more likely to be into gadgets, and more likely to pay for Prime in order to control some of your devices from your wrist…
What the exact model of your Galaxy watch? since Samsung make two different kind of watches, one is powered by it’s own OS named Tizen, and others are the original Wear OS from Google.
I’m happy to pay for the feature, although I’d much prefer to buy it through the Play/Samsung store, than as a subscription.
OTOH, happy to pay a subscription for Cast as its genuinely useful to me and requires back-end support.
We have discussion with Google wearable team, and now our feature is build on a SDK level 35, which means Android 15+ and Wear OS 5.1.0+ are both required to enable it.
And we are on the way to make adaptation for more lower Android & Wear OS versions, need time to evaluation and check with Google fellows, please rest assured, we’ll try our best to make it happen early.
I think the issue is caused by the watch, now OneUI 6.0 is build on Wear OS 5.0, with the following update from Samsung, it should be Wear OS 5.1 or higher.
Some users told us that he has update the phone to Android 16 and then update the Watch to Wear OS 5.1, everything works as expected, but this approach would be struggle, not friendly to everyone.
As my last post mentioned, we are working on make adaption for lower Android and Wear OS versions, if things go well, should be progress in Jan.
Hi, you may try updating the eWeLink app on your smartwatch. We’ve released a new update that is now compatible with Wear OS 3.0 and devices running Android 11 or above. We look forward to hearing your feedback after the update.
Updated both watch (Galaxy 6 classic) and phone (s23U) to latest versions, bought the Prime plan and was able to install the software onto the watch via the eWeLink app on the phone.
Is this a good place for feedback/bug reports, or is there another forum (or email) you’d prefer me to post to?
