【Pilot Feature】Matter Bridge is available!
It will. 2,4GHZ is supported everywhere. Zigbee standard specifies operation in the unlicensed 2.4 to 2.4835 GHz (worldwide) and for home use. For commercial and medical use, 902 to 928 MHz (Americas and Australia), 779 to 787 MHz (China) and 868 to 868.6 MHz (Europe) ISM bands are dedicated.
Why do you need it?
I want to buy a Samsung Smartthings station to add thread matter devices and control them via smartthings applications
I have a 4Gb iHost and integrated Matter with my Alexa Echo Studio. However, all of my devices migrated to Alexa with generic names. While this wouldn’t be a problem in itself, the main issue is that I am unable to control them. When I click on a plug, an error message appears stating “Server not responding.”
Typical Alexa behaviour. Overall, Matter is still in its infancy and eWeLink still hasn’t embraced integration. Wait a few hours and try again. Maybe it will start up? I wouldn’t get my hopes up too much :tipping_hand_man:
I want to use also usb to rs485 device ober ıhost usb port. how can ı configure it. for example when ı try to read over Node-red ı can see just 4 linux device for serial port but ı cannot see details. wich one should be used ?
ttyUSB0
Here’s a guide for USB dongles using with HA Core
My 3 or 2 channel ZigBee devices are not appearing, the 1 channel ones are appearing normally.
the models are TS0003(_TZ3000_wuodqwel) and TS0002(_TZ3000_pxfjrzyj)
1-channel models are working normally TS0001(_TZ3000_1jklrduj)
What would be the point of the 2 and 3 channel ones not working and the 1 channel ones working?
Sonoff WiFi switches with 1, 2 and 3 channels work normally.
Wouldn’t the implementation logic be the same?
another thing
In version 2.0
Zigbee devices stop working on Homebridge and Node-Red.
It keeps showing token error. However, WiFi devices work normally.
In this case, it would be the switches.
@ward Check this error
In IHOST CUBE v2.1.1.
*The Sonoff 4CHPro device added by matter bridge to smartthings is displayed as a single device. *
In CUBE v2.0 it was displayed as 4 devices.
the problem is out of date. the device is displayed correctly.
Matter Bridge in versions 2.0 and 2.1 became a bit unstable for some things.
In the last update with HA it stopped working correctly.
In Smartthings I’m having problems with delays!
@ociepa.ekotox @Unnamedi
Please share logs and screenshots if possible, and let our dev @SuiKa look into your issues.
Thx in advance.
