The OpenEdge initiative is undoubtedly an interesting and promising development. I particularly appreciate the move towards local control, open communication interfaces and the possibility of integrating SONOFF devices with third-party systems without relying entirely on the eWeLink cloud.
However, after going through the documentation, I am still trying to understand the overall architecture and the intended relationship between its various components.
If an OpenEdge device already supports Matter, what is the intended purpose of its additional MQTT interface? Does MQTT expose any device features, configuration options or diagnostic information that are not available through Matter?
2. MQTT RPC and device configuration
Does MQTT provide access to the complete OpenEdge RPC API, including device-specific configuration, or only a limited set of supported methods?
3. Centralized management
If a user has several OpenEdge-compatible devices, is there any central management mechanism planned? Currently, the documentation appears to describe a separate local web console and API for each device.
4. WebSocket vs. MQTT
What are the intended use cases for these two communication interfaces? Can WebSocket provide the same RPC functionality as MQTT, or is it designed for a different purpose?
5. Home Assistant integration
Is the long-term goal to make OpenEdge devices fully manageable through Home Assistant, including device-specific settings and configuration, without having to use individual OpenEdge web consoles?
I am particularly interested in understanding whether Matter is intended to be the primary integration interface, with MQTT and WebSocket providing additional functionality, or whether all three are considered equally important interfaces.
Based on my experience and testing with several products that already feature this functionality, there is a significant difference between Matter and MQTT!
Depending on the product, Matter only exports its default configuration—for instance, as a presence or illuminance sensor.
However, a sensor might also support features like zones, which are not exported via Matter, nor is their specific configuration.
In contrast, when using MQTT, everything is exported!
As for WebSocket versus MQTT, the choice largely depends on the platform; in some cases, using WebSocket is better! For example, I use it in drivers for SmartThings (ST) for testing purposes—it really comes down to the type of integration the user wants to implement!
Regarding centralized, local control: it is entirely possible to build an application that manages everything. I personally have one that handles 67 OpenEdge devices. For Home Assistant (HA) users, you can centralize everything via MQTT and manage it all from there without any issues!
Overall, I think this is a great initiative; I believe all Matter Wi-Fi products should follow this standard—it’s a very compelling approach!
In fact, I currently have everything up and running across all the platforms I use and test, with full data access—all without relying on Matter. It’s quite an interesting setup!
Thanks for sharing your experience and insights. Managing 67 OpenEdge devices is certainly impressive!
First, a question about centralized management. You mentioned having an application that manages all 67 devices. Is this something you developed yourself using the OpenEdge APIs, or is it an existing solution provided by SONOFF or a third party? I couldn’t find any reference to such a central management application in the official OpenEdge documentation. I’d be interested to know how it works and whether it’s publicly available.
I also want to emphasize that I find the OpenEdge initiative genuinely interesting and promising. I’m not criticizing the project. Quite the opposite. I appreciate SONOFF’s efforts to provide local control, open APIs, and access to the full functionality of its devices without relying on the cloud. However, your explanation raises another interesting question.
I understand that Matter currently exposes only a subset of a device’s capabilities in many implementations, while MQTT can provide access to much more, including manufacturer-specific settings such as radar detection zones and sensitivity. But does this necessarily mean that MQTT should remain the only way to access these advanced features? Could some of this functionality also be exposed through Matter, using existing standard clusters wherever possible and manufacturer-specific clusters where the specification does not provide an appropriate solution?
As I understand it, the Open Home Foundation also recognizes the possibility of supporting manufacturer-specific Matter functionality in Home Assistant, provided that the necessary technical documentation is available. Of course, this would still require appropriate implementation on the controller side.
This brings us to an issue already familiar from Zigbee, where manufacturer-specific implementations often require ZHA quirks or Zigbee2MQTT converters. I would prefer not to see Matter evolve in the same direction, with device-specific extensions becoming necessary for every new product.
That’s why I believe standard Matter clusters should be used wherever possible, with manufacturer-specific extensions reserved for functionality that genuinely cannot be represented by the standard. Ideally, Matter could become a more complete integration interface, rather than simply exposing basic device functionality, while OpenEdge would continue to offer its additional local APIs and advanced integration options.
I certainly see the value of MQTT and WebSocket, especially for custom integrations and advanced users. But I wonder whether maintaining several parallel integration paths is always the best long-term approach, particularly when Matter might be capable of handling more than it currently does. I’d be interested to hear your thoughts on this, especially given your extensive practical experience with OpenEdge.
In the last meeting I had with the CSA, the biggest issue with Matter was keeping up with new developments! For instance, there still aren’t many custom clusters that work for everyone!
This is something that’s constantly being discussed with every new version, and so on. While Home Assistant (HA) helps with implementation, it isn’t a standard in itself that everyone follows!
It was developed by my team.
It’s not a project available to everyone, partly because we use it for business proposals and the like.
The whole idea of having these protocols is very welcome!
For average—rather than advanced—users, using Matter might be the perfect solution.
For users who want a bit more, I personally believe MQTT is the better choice!
Yes, but that only applies to HA!
It doesn’t apply to every company that adopts Matter.
Many people are perfectly happy with how things work today!
I have market research showing that the vast majority of users don’t mind using a company’s specific app for setup and configuration—the only real requirement is that it functions locally.
Matter is going to suffer from the same issues that Zigbee does, and so on… this is something that will take time to resolve—if it ever gets resolved at all.
Especially now, with more companies jumping on the smart home bandwagon—introducing hubs that support Zigbee and Matter, incorporate AI agents, and so forth. (I currently have at least four new hubs of this type to test; each one offers a different approach and functions in its own unique, user-friendly way!)
I’d argue that not everyone will follow this standard unless it’s strictly enforced by the protocol itself!
I’d say long-term maintenance won’t be an issue!
For one thing, it’s hard to imagine products that are fundamentally different from what’s already on the market today—
I’m referring specifically to sensors and switches.
There isn’t much room to reinvent things or do them differently!
Any changes will likely be evolutionary—for instance, new mmWave technology that can better detect multiple people and cover more zones.
In theory, that’s not really different from what’s already available.
An energy meter that switches a load on or off,
a switch that toggles something—and so on.
So, I’d say maintenance shouldn’t be a problem!
I’d say they made the right move here.
They’re targeting a slightly different audience—it’s not entirely focused on the Home Assistant (HA) crowd.
Instead, they’re aiming at users who work in this field, building their own custom systems and the like.
As it turns out, they’ve made things a lot easier in many respects.
And, in the process, they’ve also made life easier for those of us who use Home Assistant!
Personally, I find it much easier to work with MQTT than with Matter, haha.
Thanks for the detailed response. It’s particularly interesting to hear this from someone who has direct contact with the CSA. I obviously don’t have that kind of access, so I follow Matter developments mainly from the end-user perspective.
I understand the CSA’s cautious approach. I imagine they want to avoid a situation similar to what we’ve seen with Zigbee, especially in the Tuya ecosystem, where manufacturer-specific implementations have led to considerable fragmentation. A common standard is only meaningful if devices can actually communicate and work together without every manufacturer introducing its own interpretation.
At the same time, I fully agree with your criticism of the pace of Matter development and the lack of timely support for new device capabilities. A standard may be well designed in principle, but if its specifications and implementations fail to keep up with the products appearing on the market, manufacturers and integrators inevitably look for alternatives.
This is where I see OpenEdge as a very practical solution. It provides access to the full local functionality of devices without having to wait for Matter specifications or controller implementations to catch up. MQTT, RPC and WebSocket make a lot of sense in this context, and I can understand why you find MQTT more convenient for your work.
However, I wonder whether there might be an opportunity to take this a step further. If other manufacturers independently develop similar solutions, we could end up with another form of fragmentation: instead of different Zigbee quirks and converters, we’d have different proprietary local APIs and integration mechanisms for every brand.
Perhaps it would be worth considering inviting other manufacturers to participate in the OpenEdge project. If it evolved into a genuinely shared specification, rather than remaining a manufacturer-specific solution, it could offer a common local interface for advanced device functionality. That would require cooperation on the protocol and its capabilities, of course, but it might be a way to combine flexibility with interoperability.
I also wonder whether Matter could complement this approach much more effectively than it currently does. I don’t expect standard Matter clusters to cover every manufacturer-specific feature, but I think they should be used wherever possible, with manufacturer-specific clusters reserved for functionality that the standard doesn’t adequately address.
The Open Home Foundation’s approach is interesting in this regard: with proper technical documentation, Home Assistant can potentially support manufacturer-specific Matter functionality as well. Of course, this doesn’t automatically guarantee compatibility with other Matter controllers, but it shows that the current limitations don’t necessarily have to be permanent.
Ideally, I would see these approaches as complementary rather than competing: Matter providing the standardized interoperability layer, while OpenEdge offers richer local access to device configuration and advanced capabilities. And perhaps, with broader industry participation, OpenEdge could become something more than just another proprietary ecosystem.
I think that would be a very interesting direction to explore.
But this is something that has existed on the market for years—it’s not just Tuya that offers this.
In fact, all other brands that don’t rely on Tuya already have their own open protocol standards; for example, Shelly has been exporting its data via its own protocols—such as MQTT—for years.
I don’t think there are enough other companies out there to cause the kind of major fragmentation that we already see with Matter and Zigbee!
I think we may be talking about slightly different things here.
I’m well aware that manufacturer-specific local APIs and protocols have existed for years. Shelly is a good example. My point wasn’t that OpenEdge introduces something new, but that having MQTT or a local API doesn’t automatically mean having a common interface. MQTT is just a transport protocol; different manufacturers can still expose completely different data structures, commands and configuration options.
That’s why I wondered whether inviting other manufacturers to participate in OpenEdge might be worth considering. Not to introduce yet another proprietary solution, but perhaps to establish a more common approach.
Regarding Matter, I agree that manufacturer-specific clusters are already supported. The issue, as I see it, is not their availability but their practical interoperability and support across controllers. And I don’t think this situation is unchangeable. More standard clusters, better specification coverage and improved controller support could all help.
Perhaps our perspectives simply differ: you’re looking at this from the perspective of someone working with these technologies, while I’m looking at it as an end user who would ideally prefer not to need a different integration mechanism for every manufacturer.
I agree with you!
However, that is not what the vast majority of people think.
Home Assistant (HA) is larger today than it was in the past.
Yet, it still represents a very, very small fraction of the smart home user base!
All the recent meetings I’ve had with the CSA, Samsung, Google, Amazon, LG, and others point in a different direction!
Most are focusing on local operation, but they aren’t following the same approach as the Open Home Foundation—because market research consistently shows that customers themselves don’t really care about the philosophy that the Foundation advocates!
The only “philosophy” many users care about these days is having a system that works locally, without depending on the cloud!
And that is exactly what all the major brands are already implementing and pursuing!
I agree with parts of this, but for it to happen, there would be a cost—a need for ongoing maintenance—that I don’t think most companies are very keen on taking on!
Like it or not, they are the biggest player in the market—they have the most active users, sell the most devices, and reap the most profit from the whole ecosystem.
To be perfectly honest, they offer a very solid range of products and customization options—things that the Zigbee standard itself doesn’t support, nor do Matter or Thread.
Every time I’ve visited Tuya’s headquarters, I’ve seen some incredible, even wild, projects!
In fact, I have major clients with setups comprising 320 Wi-Fi-based Tuya devices that have been running smoothly for at least 10 years without any issues.
Similarly, I have clients with systems based on Sonoff products that have been in operation for years; they are all very happy with the implementation and how everything functions!
I think Sonoff saw an opportunity to create something that was missing, allowing them to reach a segment of the market they hadn’t tapped into yet—the idea was implemented, and it works well!
I’ve seen the circuit breakers that follow this protocol, and they look quite promising!
The whole project seems very promising, especially since it’s aimed at a market Sonoff was already serving—though previously, users had to perform firmware modifications and the like. Now, with this, everything has become much simpler to handle and resolve!
Another point is that even if everyone creates their own solution, they might all end up converging on the same path—for instance, using MQTT, WebSockets, or similar protocols. This would make things much easier, and I wouldn’t necessarily call it “fragmentation”!
It’s essentially the same thing, just under a different name.
As it stands, one could argue that there aren’t actually that many independent IoT product manufacturers; most offerings come from companies like Tuya, eWeLink, Shelly, or Xiaomi.
I agree—you’re looking at this from the perspective of an end user!
That perspective is quite different from how the industry operates today.
What we’re seeing emerge with Matter now has actually been in development for a long time.
Matter continues to evolve, but not all manufacturers keep up with every update; most invest significant capital into development and need to recoup those costs.
That’s essentially how things work!
That’s why some manufacturers release V1, V2, and so on.
I agree with that. However, my point is that only advanced users will end up using protocols other than the product’s default one!
That’s why I say this isn’t very important—
because advanced users will consult the documentation and so on…
Average users just want to plug it in, and it should simply work!
I imagine that the people who will actually use all these solutions and protocols are advanced users—not typical, everyday users!
Because of this, the idea of having a standardized way of presenting data (like via MQTT) doesn’t really make much of a difference. Any manufacturer willing to offer connectivity via these advanced protocols for the average user would simply provide the necessary documentation. So, for an advanced user, this wouldn’t be an issue at all!
As for the typical user, they would simply stick to the product’s native protocol—whether it’s Matter, Wi-Fi, or anything else. For the average person, as I mentioned before, it makes no difference!
Just last month, my company conducted market research across Asia, surveying over 10,000 smart home users. Most of them weren’t concerned with technical details; they only cared that things worked locally and functioned reliably without requiring complex setup.
Out of those 10,000 people, only 500 had even heard of Home Assistant (HA).
The vast majority used Alexa or Google Home as their primary platform.
Furthermore, a significant portion used systems from Samsung or LG, while others relied on solutions implemented by local companies—often built on platforms like Tuya or similar services.
There is more data, but I cannot share it, as it belongs to the company that commissioned the research!
So, yes—the perspective of the end user can be vastly different!
The vast majority of users aren’t even aware that this fragmentation exists in the market!
I agree that most users don’t care about technical details as long as their devices work reliably. But does the fact that most users aren’t aware of fragmentation mean that it isn’t worth addressing?
Tuya is a good example of why I think it matters. I’ve come across many disappointed users who assumed that the Tuya label guaranteed compatibility. Unfortunately, it doesn’t. Behind that common label, there are devices from numerous manufacturers, often with different Zigbee implementations, manufacturer-specific clusters, unusual naming conventions and inconsistent device identification. What looks like one ecosystem from the outside can turn out to be a rather confusing collection of incompatible implementations. And yes, I hate Tuya
The average user doesn’t need to understand any of this. But they do expect a compatibility promise to mean something. And they often discover the limitations only after buying the device.
I also have some reservations about the argument that advanced users can simply read the documentation, write their own integrations or configure MQTT. Of course they can. But should the lack of a common data model really be considered unimportant just because technically skilled users can work around it? That’s a bit like saying we don’t need common standards because developers can always write another converter. Standards exist precisely to avoid having to reinvent the wheel for every manufacturer.
Fragmentation may be invisible to ordinary consumers, but it still creates costs for manufacturers, integrators and platform developers. And users can certainly experience its consequences without knowing what causes them. So perhaps the real question isn’t whether ordinary users care about what’s under the hood, but whether the industry should make sure they don’t have to care about it in the first place.
And perhaps this is where our different perspectives can actually complement each other. People with your professional experience and those of us who approach these technologies as advanced users may be able to contribute something useful to the discussion. Individually, our influence may be limited, but a shared effort to highlight these issues might eventually help shape the decisions made by manufacturers and standards organisations.
I have to disagree here!
The Tuya seal guarantees proper operation within the Tuya ecosystem—not in Z2M, Home Assistant, or anywhere else.
Within the Tuya ecosystem, it is guaranteed that the device will function correctly and offer all the capabilities it was designed to have, regardless of whether it is a Matter, Wi-Fi, Zigbee, or Bluetooth device.
I understand that Tuya provides a common ecosystem, but even within that ecosystem, full functionality isn’t always guaranteed. Interestingly, Tuya’s own documentation acknowledges that some custom device functions may not be displayed by standard app panels, that certain functions require custom panels, and that manufacturers are responsible for defining which capabilities are exposed.
Tuya also explicitly acknowledges that some functions may not work correctly when Zigbee devices from different manufacturers are interconnected, even when they comply with Zigbee 3.0 and carry the Tuya logo.
So I’m not questioning the idea of a common ecosystem. I’m questioning whether its label alone guarantees the level of compatibility and functionality users might reasonably expect. And this brings me back to my original question: does the fact that most users aren’t aware of fragmentation mean that it isn’t worth addressing?
I’ve noticed that.
I have nothing against people having different perspectives—that’s actually healthy and good.
However, the vast majority live inside a “bubble,” and that bubble is usually very hard to break!
Naturally, if you don’t like Tuya, Sonoff, or whatever else, you’ll find other users who are equally dissatisfied and looking for a change—and they’ll go out and pursue that change!
But such a change is almost always difficult and painful!
We could sit here for hours discussing this and get absolutely nowhere!
That’s simply because our viewpoints differ.
And that’s fine.
But let’s be honest: when companies are generating thousands of dollars in revenue, a lot of questions inevitably arise!
I happen to be one of the 1% involved in this space; I’m in contact with almost every company in the market, I have investments in them, I participate in projects with them—and so on!
And when I talk about market research, you might be skeptical—arguing that we should fight for change, and so on…
But the plain truth is this:
The end user just wants to install something that works—period. They don’t really care about what’s happening behind the scenes or how it functions!
As you’ve pointed out yourself:
Matter could evolve, support more clusters, and so on…
That’s the mindset of someone who just wants to buy a device, plug it in, and have it work exactly as it’s supposed to—simple as that!
The point is straightforward.
Nowadays, all these platforms offer hubs that support every protocol!
So, for the vast majority of users—excluding the 2% that you and your friends belong to—it doesn’t really make much of a difference!
That said, I do agree with you on certain points!
But these are points that the market as a whole needs to embrace! Matter, Thread, Wi-Fi, Zigbee 3.0, Zigbee 4.0, Z-Wave, and so on—they exist, they will continue to exist, and they’re here to stay; for all we know, a new protocol could pop up at any moment!
I disagree here.
It does acknowledge issues with touch panels and the like.
This is another area where limitations exist—and these limitations are usually determined by the manufacturer’s choices!
For example, if Company X launches a touch panel, everything from that company will work perfectly on it—but products from Tuya (or other brands) might not!
That’s because the panel was commissioned specifically by Company X.
You’ll rarely find touch panels on the market that are actually manufactured by Tuya itself!
Another point is that there are relatively few devices actually manufactured and distributed by Tuya!
The “Tuya” seal means that a Tuya hub or the Tuya app will recognize the device and work with it correctly.
However, depending on the specific device, there may be restrictions imposed by Tuya itself!
This is because the company that commissioned the device can lock it to their own proprietary app, thereby limiting its functionality.
I mention this because I have ordered such products directly from them for my own clients!
The problem is that Tuya’s business model is very confusing for the user!
Sales through AliExpress only add to this confusion.
Often, people end up buying from various manufacturers—some of whom may be selling devices with expired licenses, counterfeit products, or even leftover stock from other projects!
As a result, there is a huge amount of inconsistency!
That is why I always recommend that if you’re going to buy a Tuya-based product, you should purchase it from well-known brands, such as Zemismart, etc.!
I understand your point about the market, business realities and what most consumers expect. I’m not disputing that. However, I’d like to clarify something regarding your “bubble” comment.
I’m not claiming that Home Assistant represents the entire smart home market, nor am I suggesting that everyone should use it. I simply discuss things from the perspective I know best. I use HA, so naturally I evaluate interoperability and device integration through that experience. I also deliberately avoid making claims about other platforms I don’t know well enough.
I believe Home Assistant is currently one of the most effective examples of bringing very different technologies and ecosystems together in a single environment. Its breadth of integrations, substantial user base and commitment to local control make it a particularly relevant reference point for this discussion. I’m not saying it’s the only platform doing this, but I do think it does it exceptionally well.
I also understand that you look at things from the perspective of someone working in the industry, with direct knowledge of manufacturers, investments, development costs and market research. That’s valuable, but it doesn’t make the end-user perspective any less relevant.
Ultimately, I think we actually agree on the most important point: users simply want their devices to work reliably and without unnecessary complexity. Where we differ is in how to achieve that. From your perspective, the market has its own priorities and commercial realities. From mine, better interoperability and more consistent standards are part of the solution, not merely a technical ambition.
I don’t think having a clearly defined perspective is the same as being trapped in a bubble. Perhaps that’s precisely why discussions between industry professionals and experienced end users are worthwhile. One side understands the constraints, while the other experiences their consequences. A combination of both perspectives might help influence the decisions made by manufacturers and standards organisations.
