NSPP fw:4.5.3 feedback
Why can’t I pin scenes and devices in NSPP? I have an established order, but every time I add a new scene or device, the order gets messed up and I have to fix it on all NSPPs in the house. It’s very annoying.
What’s new in 4.5.3 ?
@Milk For some unknown reason, every time I turn on the irrigation in the evening, it turns on the LED strip. The LED strip and the irrigation are not connected to each other. I recently sent the log files of the device IDs: 1002b3b969 ,10022e4d55 and irrigation is connected to 100265651a . They are all NSPP with the latest software.
Sorry for the late reply.
Just to confirm, is your LED strip a Bluetooth LED strip? Did you link it to the NSPanel Pro (1002b3b969) as a sub-screen device?
Also, does the incorrect automation occur every time the irrigation starts?
I noticed that you have several Zigbee water valves under your account. Could you let me know which specific valve triggers this issue? Have you checked the activity log of the LED strip to see what it shows when the unexpected action occurs?
Sorry, I missed your previous message.
Just to clarify, do you mean that every time you add a new device, the order of the device and scene widgets you’ve already arranged gets changed? Normally, a newly added device should simply appear at the beginning of the list, while the existing order should remain unchanged.
Or do you mean that when you add a new NSPanel Pro, you don’t want the device and scene widgets to be synchronized automatically?
I have a Sonoff L3-5M RGB LED strip. I can’t see anything bad in the log files, but every evening when the load is turned on, the LED strip turns on. There is nothing in the scenes.
When I turn off any alarm, it loses its settings.
