NSPanel Pro + TRVZB + ZBMINIR2
Hi, I have configured a NSPanel Pro with 6 TRVZB and a ZBMINIR2 to activate the water heater.I want this configuration because don’t depend from wi-fi or internet.I have added to NSPanel Pro 6 thermostats, one for any TRVZB, the problem is that settings are indipendent from thermostat and the TRVZB, what I have to do?Also changhing the thermostat don’t make the ZBMINIR2 to switch, but if switch manually the “heating” indicator is visibile.For now I have created a scene that switch the ZBMINIR2 like the TRVZB heating or idle, this work, but I don’t want to use a scene.
What I have to do make those things working as expected?
Thank you very much for using NSPanel Pro.
It seems our new Central Heating System which is in alpha stage would fit your needs. Please refer to NS Panel Pro Thermostat problems - #138 by MichaelLearnsToCode for details.
If you want to try it, please send me the Device ID of your NSPanel Pro through private message.
Hi, what firmware version do you have in nspp?
We are currently testing central hearing system that solve this deficiency.
The version is 4.1.5 I will try the central heating system, I will message to Michael.
You need 4.2.3 for central heating system.
Hey, I don’t want to chase after my bug. I have a draft house with independent heating zones. And I want to properly test the central hearing system.
