I’m using an NSPANEL pro with the thermostat function connected to a ZBMINI as the actuator device.
All is working as expected, the problem is that when the termostat is set to OFF then the ZBMINI status can be set independently from the thermostat device and this result in a wrong activation of the heating / cooling device…
My suggestion is that the actuator device (ZBMINI) linked to the thermostat MUST BE always driven by it avoiding external set when the thermostat is off… this behavior is already in place when the thermostat is ON… so why it is not also available when the thermostat is off?
D
