NSPanel Pro Gen2 disable touchscreen relay buttons
I have a scenario where I want to use my NSPanel Pro Gen2 as a thermostat using one of the relay outputs as a call for heat. It doesn’t appear possible to do this, so have created a thermostats on Homeassistant that switched the relay on/off based on a temperate input.
I would like to disable/hide the touchscreen relay buttons so I don’t accidentally turn on the heating from the touchscreen. Is this possible ?
Hi, You can find the NSPanel Pro Gen2 in the eWeLink app, go to Theme Settings, and change the theme style to achieve the effect you want.
