@ward @Archarr I have been watching for a couple of days and it is indeed better.
In the evening, however, I noticed something that had not been there before. A slight change, a ‘pulsing’ of the screen brightness when the panel has the auto adjust and the saver (e.g. the clock) set. Unfortunately, this cannot be captured with the camera on the phone. When you change to constant brightness, the pulsing is not there. For this to occur, there must be some weak source of diffused light in a dark room. In my case, the ‘trigger’ is, for example, the screen of a network player. It is not a phenomenon that prevents you from using the panel, but it is annoying because you subconsciously direct your eyes towards it.
Are there slight changes in brightness? Like waves of water
Well, you can call it this waves. Anyway, it is not very rapid and seems to be irregular.
I see, we will try to restore the issue. And let you know the results.
Created a new topic for this.
There’s a change in the algorithm of auto brightness which was meant to solve the “laziness” on some occasions.
The NSPanel Pro team will keep optimizing this.
This explains the issue.
