NSPanel Firmware release
I also like the fact that you can change it back from manual to auto now without depending on the App
The screen use to give you a big warning message on the NS Panel (not the pro) to use the eWeLink to change it back to auto if required.
You could take it out of auto, but on the last firmware you could not change it back.
Nice !!
My second NSpanel86PB doesn’t not receive firmware update
Can anyone knows how to disable ADB debugging on NSPanel Pro
Once activated is not possible to disable ADB !
This topic has been discussed many times on the forum. See here or there. Using Search on any forum is highly recommended.
I can see that the fancy and unrestrained electrics are adjacent to the gas line. A bit like a scene from horror films. Aren’t you afraid you’ll demolish yourself and your neighbours?! Because if this happens, the public prosecutor will certainly be concerned.
I could argue , but I’m not going to justify this remark.
Many thx for the ideas.
But for other users,
:warning: Please be aware of the wiring ideas shared by communities. If you are no pro electrician and unfamiliar with local regulations against such modification, please seek professional consultation before following any steps. This could be more serious when gas lines are involved.
Hopefully on next Ns Panel (Pro) update we will have “separate tiles” Ihave this double switch, one tile for kitchen and one for garden lights. 2 totally separate zones that I cant separate on the NS Panel…
