More NSPanel (pro) in the network
Hey!
I just bought another 2pcs NSPanel pro.
So now I have 3pcs in the same home (phisically and in the ewelink app too)
It doesnt matter its in hub mode or router mode.
There should be an option, what function I want to sync with the new one. (Or share not with a user, but a device.)
E.g.:
#1 Thermostate setting. If I make another thermostate which operate the same device, I can’t turn it off, because the other.
The 2 or 3 device should be in sync! …if i make a settings for it. Or just sync with the second device, but not with the third one.
#2 The same in the security menu!
What do you think about it? :slight_smile:
Be more specific, please.
Click:
  1. The main NSPanel pro
  2. Thermostate menu
  3. “Livingroom” thermostate (or any other if you have more)
  4. Settings (upper right corner, 3 dots)
  5. Here a new option: “Sync with”
    And you can check the other NSPanel with which you want to sync the “Livingroom” thermostate. So I can operate the heating from 2 different location.
I see. Surely it is a good idea.
Great idea.
Don’t forget to vote for your own post:
Screenshot 2024-09-26 at 10.16.59
